Real analysis show f is continuous
The problem involves a function \( f \) defined by the property \( f(x+y) = f(x) + f(y) \) for real numbers \( x \) and \( y \). The original poster is tasked with showing that if \( f \) is continuous at 0, then it is continuous everywhere.
  • Participants discuss proving properties of \( f \), such as \( f(0) = 0 \) and \( f(-x) = -f(x) \). There is mention of using an epsilon-delta argument for continuity. Some participants explore the implications of the functional equation and the form of \( f \). Questions arise about how to deduce certain properties and the nature of solutions to the functional equation.
Participants are actively engaging with the problem, exploring various properties of the function and discussing potential approaches to proving continuity. Some have provided hints and suggestions for proving specific properties, while others express uncertainty about the deductions involved.
There are indications of confusion regarding the implications of the functional equation and the continuity condition. Some participants note the existence of non-continuous solutions to the functional equation, which adds complexity to the discussion.
zachsdado
suppose f is a function with the property f(x+y)=f(x)+f(y) for x,y in th reals. suppose f is continuous at 0. show f is continuous everywhere.
I do not understand how to show that f is continuous everywhere.
Try to see what properties f has. For example, try to prove that f(x-y) = f(x)-f(y). (Hint: Prove first that f(0)=0 and f(-x)=-f(x).)
Then use an epsilon-delta argument to prove that f is continuous everywhere.
Use the definition of continuous: f is continuous if and only if [itex]\lim_{x\rightarrow a}f(x)= f(a)[/itex].
Now, let h= x- a and write that in terms of [itex]\lim_{h\rightarrow 0}[/itex].
Exactly the same proof can be used to show that if such an f is continuous at any specific x, then it is continuous at x=0. Putting the two together, if a function satisfying f(x+y)= f(x)+ f(y) is continuous for any x, then it is contnuous for all x.
And, by the way, f must be of the form f(x)= Cx for some number C. The really remarkable thing is that there exist function satisfying f(x+y)= f(x)+ f(y) that are not continuous!
ok I have deterimed that i can not do this problem. I do not not even understand how two deduce that f(0)=0
You know that f(x+y)=f(x)+f(y). What happens if you plug in x=y=0?
you have f(0)=f(0)+f(0)
So...
how is this 0
f(0)-f(0)=f(0)+f(0)-f(0)
0=f(0)
That's good. Now can you show that f(-x)=-f(x)? (Try to plug in "clever" values for x and y in f(x+y)=f(x)+f(y).)
If you prefer, I also think an [itex]\epsilon-\delta[/itex] proof is not very hard in this case.
In fact we can solve this functional equation. Suppose that f is continuous at 0. Then f(0+0)=f(0)+f(0) so f(0)=0. Now [tex]\lim_{y\to 0}f(x+y) = \lim_{y\to 0}f(x)+f(y) = f(x)+f(0)=f(y)[/tex] so [tex]f[/tex] is continuous everywhere. Let [tex]f(1)=c[/tex]. But using the argument f(1+...+1) = nf(1) you can show that f(n)=nc. Now consider a rational number p/q with p,q>0 so if x=p/q then qx=p and so f(qx) = p so f(x+...+x)=p thus pf(x)=ap; that means f(p/q) = a*(p/q). We can extend this argument to negative also easily. And so if x is any real number there is a sequence of rationals converging to it so f(x) = a*x because this is true for rationals. Thus, the only possible functions are the lines through the origin.
There do, however, exist non-continuous solutions to that functional equation. In distinction to the continuous solutions, all of the form f(x)= Cx, non-continuous solutions are remarkably messy- there are "dense in the plane".
Trivial? Use axiom of choice and contruct the Hamel Basis.
I didn't say it wasn't easy! I'm not sure I would consider contructing a Hamel basis trivial, though. This is one of those situations where it is easy to tell HOW to do something, just very difficult to do it. "First construct a basis for the real numbers as a vector space over the rational numbers"- It's very easy to see that we can use "1" as a basis element and then [itex]\sqrt{2}[/itex] as another, ... but not clear to me how I could give the entire basis. Now define f(1)= 1, f([itex]\sqrt{2}[/itex])= 2, f(v)= 0 for v any other member of the basis, and define f(x) for any real number x "by linearity". Then we have a function satisfying f(x+ y)= f(x)+ f(y) (and f(rx)= rf(x) for any rational r) but which is not continuous.
(I think we have gotten well off the original question now!)
  • · Replies 21 ·
  • · Replies 20 ·
  • · Replies 27 ·
