Mod-11 Ripple Counter Homework: Solve Error w/T Flip-Flops
  • Thread starter Thread starter Bryan52803
    Counter Ripple
The discussion centers on creating a mod-11 ripple counter using T flip-flops and standard logic gates in Quartus II simulation software. The primary issue identified is a race condition causing the third bit to toggle prematurely when the counter reaches decimal 11, resulting in an incorrect reset to 4 instead of 0. A suggested solution involves adding an additional flip-flop in the reset path to extend the reset signal duration, ensuring it does not interfere with the subsequent clock pulse.
  • Understanding of T flip-flops and their operation
  • Familiarity with Quartus II simulation software
  • Knowledge of ripple counter design principles
  • Concept of race conditions in digital circuits
  • Research how to implement race condition mitigation techniques in digital circuits
  • Learn about the behavior of reset inputs in flip-flops
  • Explore advanced ripple counter designs and their applications
  • Study the timing diagrams and waveforms in Quartus II for better debugging
Electronics students, digital circuit designers, and anyone involved in designing or troubleshooting ripple counters and flip-flop based systems.
Bryan52803
Create a mod-11 ripple counter using Flip flops and standard logic gates. Only usable flipflops are T,D, and JK. I've used T.
Using Quartus II simulation software
I have the block diagram all done and the simulation. Everything works fine. Except! When the 4 bits get to decimal 11(when its supposed to reset back to 0), it does with every T-flip flop except the third bit. So the decimal when it "resets" is equal to 4, not zero. It actually changes the third bit from 0, to 1 prematurely. I've attached the block diagram and the simulation waveform file with the error pointed out. Any help or hints would be greatly appreciated! Maybe I'm misunderstanding how the reset input works, but unfortunately I have a very poor teacher and the class is usually left to fend for itself in terms of teaching and clarification.
Bryan
This is why nobody wants to use ripple counters, they're awful!
There's nothing wrong with your circuit, you can see that with symmetry; you have a problem with bit 3 which should be the same as bit 2 etc. I think the problem is a race condition because the reset pulse is too short, When bit 2 resets it puts a clock pulse into bit 3 which toggles it. Since 11dec = 1011bin, bit 3 switches from 0→1, all of the other bits would switch from 1→0, which you wouldn't notice.
You could try adding another FF in the reset path to hold that signal for 1/2 clock period. But the reset must go away before the next clock input.
13K
  • Sticky
9K
