How Does a Moving Coil in a Loudspeaker React to a Fluctuating Voltage?
  • Thread starter Thread starter belfunk
    Coil
The discussion centers on the physical mechanisms governing the behavior of a moving coil in a loudspeaker when subjected to fluctuating voltage, as well as the formulation of a differential equation for a stationary coil under similar conditions. The scope includes theoretical understanding and technical explanations related to electromagnetism and loudspeaker operation.
  • Homework-related
  • One participant seeks to understand how fluctuating voltage affects current flow in a moving coil within a magnetic field.
  • Another participant explains that the loudspeaker coil acts like an inductor and that the current generates a magnetic field that interacts with a stationary magnet, producing motion.
  • A participant describes the operation of an electromagnetically driven loudspeaker, detailing the interaction between the coil and the magnetic field and its role in sound production.
  • There is a question about why the coil moves instead of the permanent magnet, indicating a curiosity about the mechanics of the system.
  • One participant expresses uncertainty about the relationship between the coil's movement and the current flow, suggesting that the coil cutting through the magnetic field may influence the current.
  • Another participant mentions the need for a differential equation to describe the behavior of current in a stationary coil, indicating ongoing efforts to understand the relevant equations.
Participants generally agree on the basic operation of the loudspeaker and the role of the coil and magnet, but there remains uncertainty regarding the specific mechanisms of current flow and the formulation of the differential equation. The discussion does not reach a consensus on these technical aspects.
Participants express varying levels of understanding regarding the physical principles involved, and there are references to external resources for further reading. The discussion includes assumptions about the behavior of the coil and the magnetic field that are not fully resolved.
belfunk
can anyone help with me understanding the physical mechanisms that determine the current that flows through a MOVING coil immersed in a magnetic field when a fluctuating voltage is applied across the coil?
Also I need to find a Differential Equation that describes the behaviour of the current flowing through a STATIONARY coil when a voltage is applied across it?
Any help would be greatly appreciated.
Cheers,
belfunk.
Welcome to the PF, belfunk. I've moved your post to the Homework Help forums, where homework and coursework questions should be placed.
We discussed speaker cone movement a bit in this recent thread:
https://www.physicsforums.com/showthread.php?t=190829
The speaker coil on the back of the cone basically looks like an inductor with loss from the energy that gets imparted to the air to make the sound. The voltage across the inductor causes a current to flow, and this current generates a magnetic field that interacts with the DC bias magnet to cause forces. Can you show us some of your work on this question? You are required to show us your work in order for us to provide you with some tutorial help.
well the 1st question of my essay was to describe the form and operation of an electromagnetically driven loudspeaker. This was my answer:
"An electro-magnetically driven loudspeaker comprises of a moving coil. The moving coil is used to convert electrical signals into acoustic energy. The coil of the loudspeaker is located in an air gap in which there is a magnetic field produced by a permanent magnet. Then an amplified audio signal is applied to the coil. This voltage causes interaction between the current in the coil and the magnetic field from the permanent magnet, causing the coil to vibrate, and this motion is transmitted to a radiating element normally in the form of a conical diaphragm."
For my own interest, not my assignment can someone tell me why the coil moves and not the permanent magnet?
The next question is to describe the physical mechanisms that determine the current that flows through a moving coil immersed in a magnetic field when a fluctuating voltage is applied across the coil.
I assume that the movement of the coil cutting through the magnetic field of the permanent magnet will determine the current... is this true? I am struggling to find anything about this on the net.
I'm still trying to understand the differential equation question. I've been given some equations, but I'm trying to get my head around them.
The stationary magnet is fixed in the loudspeaker, so the only thing that can move is the speaker cone, with the coil attached to the cone. The force that moves the coil and cone comes from the current interacting with the stationary magnetic field.
This wikipedia.org page is a pretty good introduction, with some good links for further reading:
http://en.wikipedia.org/wiki/Loudspeaker
thanks for the help berkeman. much appreciated.
  • · Replies 16 ·
  • · Replies 27 ·
  • · Replies 16 ·
