Ladder vs Wall Homework - Force Calculation
  • Thread starter Thread starter Dante5454
    Wall
The discussion centers on calculating the forces exerted by a wall and the floor on a ladder in static equilibrium. A 10m ladder weighing 180N is positioned against a smooth vertical wall, with a person weighing 652N standing 3.2m up the ladder. The foot of the ladder is 5.7m from the wall. The participant initially assumed that the forces exerted by the wall and the floor would be equal, but later realized that the force from the floor has both vertical and horizontal components, which complicates the calculations.
  • Understanding of static equilibrium principles
  • Proficiency in applying Pythagorean theorem in physics
  • Knowledge of torque calculations
  • Familiarity with trigonometric functions in physics
  • Study the concept of static equilibrium in detail
  • Learn how to calculate torques in various scenarios
  • Explore the role of force components in static systems
  • Investigate the application of trigonometric functions in force analysis
Physics students, engineering students, and anyone involved in mechanics or structural analysis will benefit from this discussion.
Dante5454
A 10m ladder whose weight is 180N is placed against a smooth vertical wall. A person whose weight is 652N stands on the ladder a distance of 3.2m up the ladder. The foot of the ladder rests on the floor 5.7m from the wall. What is the force exerted by the wall? What is the force exerted by the floor? (Answers in N)
Static Equilibrium, so Sum of Torques=0, Sum of Forces in the y-direction=0, and Sum of forces in the x-direction=0
I think the two answers should be the same, because they are the only two forces acting in the x-direction.
I first solved for the height of the ladder off the ground using pythagorean's theorem. Then, with trig, got both the angle of the ladder to the floor and the ladder to the wall. I placed the pivot point at the floor and calculated each torque, one for the man, using (distance up ladder)*(weight of man)*(cos of angle between ladder and floor) and one for the ladder using (half the length of ladder)*(weight of ladder)*(cos of angle between ladder and wall). Dividing that answer by (height of ladder off ground)*(cos of angle between ladder and floor) SHOULD have given me the force of the floor against the ladder, which would have been the same as the force of the wall against the ladder, but it was incorrect when I submitted it. Thanks!
Careful! The force exerted by the floor has both a vertical and a horizontal component.
  • · Replies 20 ·
