Conservation of Mechanical Energy in a ball of clay
The problem involves a 50 g ball of clay colliding with a 1.0 kg block at rest on a frictionless surface, focusing on the conservation of mechanical energy during the collision.
  • Participants discuss the momentum conservation equation and its application to find the speed of the block after the collision. There is uncertainty about the correct expression for kinetic energy before and after the collision, with some questioning the setup and definitions used in the energy comparison.
Some participants have provided guidance on how to approach the kinetic energy calculations and the comparison of initial and final energies. There are multiple interpretations of the energy expressions being discussed, and participants are exploring the implications of these calculations.
Participants note the absence of potential energy in this scenario and the need to express results in terms of the initial speed of the clay ball. There is also mention of confusion regarding the inclusion of certain variables in the equations.
octahedron
A 50 g ball of clay traveling at speed [tex]v_0[/tex] hits and sticks to a 1.0 kg block sitting at rest on a frictionless surface.
a. What is the speed of the block after the collision?
b. Show that the mechanical energy is not conserved in this collision. What percentage of the ball's initial energy is "lost?"
For part (a), I just said
m_1*v_0 = (m_1 + m_2)*v_1
0.05*v_0 = (0.05+1)*v_1
v_0 = 21*v_1
I'm hoping this is correct! Now, part (b) I'm not entirely sure of. I guess there is no PE in this case so I should show that
(.5)(m_1)(v_0)^2 [tex]\neq[/tex] (.5)(m_1)(v_0)^2 + (.5)(m_1)(v_1)^2
Is this it? How do I go on about finding the percentage "lost"?
This is fine.
v_0 = 21*v_1
Not sure what happened here. Find v_1 in terms of v_0.
This expression seems a bit mixed up. Find the initial KE (the left hand side). Find the final KE (you'll need the speed of the combined masses from part a). (Express everything in terms of v_0.)
Compare the two KEs and find their difference (the loss of KE). Then you can figure out what percentage of the original KE that loss is.
Is the right side of the equation your after? If it is, v_0 shouldn't figure into it, I don't believe.
Initial KE = Ei = 0.5*m1*Vo^2
Final KE = Ef = 0.5*(m1 + m2 )*V1^2
Show that Ef is not equal to Ei. And percentage loss = [(Ei -Ef)/Ei]*100
Thanks everyone, got it! :)
Oops! I didn't mean to include v_0 there. Sorry for the confusion.
  • · Replies 18 ·
