Calculating Torque and Work: Flywheel Mass, Radius, and Time Interval
  • Thread starter Thread starter Jtappan
    Torque
The problem involves calculating torque and work for a flywheel with a specified mass and radius, transitioning from rest to a certain angular velocity over a given time interval. The subject area includes concepts from rotational dynamics and energy.
  • The original poster expresses confusion about how to approach the problem when time is involved, having only calculated the moment of inertia. Some participants suggest converting angular velocity and using kinematic equations to find angular acceleration. Others discuss the relationship between torque and moment of inertia, and the method for calculating work in terms of kinetic energy.
Participants are exploring various methods to solve the problem, with some providing guidance on converting units and applying relevant equations. There is an ongoing exchange of ideas regarding the calculation of work and the appropriate formulas to use, but no consensus has been reached.
Participants are navigating the complexities of rotational motion, including the need to consider both torque and kinetic energy in their calculations. The original poster's uncertainty about the role of time in the problem setup is noted.
Jtappan
A flywheel of mass 181 kg has an effective radius of 0.63 m (assume the mass is concentrated along a circumference located at the effective radius of the flywheel).
(a) What torque is required to bring this wheel from rest to a speed of 118 rpm in a time interval of 29.4 s?
_____ N·m
(b) How much work is done during the 29.4 s?
______ kJ
How is this problem done when time is involved?? I am confused.
I have done I = mr^2 and that's it.
they give you 118 rpm. You have to convert that to angular velocity using factor label.
You have time and final angular velocity, so you can find angular acc. using Vf = Vi + at where Vf=final angular vel, Vi = initial angular vel (which is 0 in this case), a=angular acc, and t=time.
then just use your I = mr^2, but remember that T=Ia (torque = I * alpha) and remember that torque=F*d.
Good luck!
Bump...I am working on a similar problem and having trouble with part b. I have found the torque and I thought to find work I could use w=td where t is torque and d is rotational distance. What am I missing?
Work is the change in kinetic energy. KEf - KEi, but since its at rest in the beginning, its KEf - 0, which is just w=KEf. Remember to consider rotational kinetic energy, because it is rotating. Good luck to you both!
10K
