Thread Closed
Inertia question
Share Thread Thread Tools
Nov15-07, 03:29 AM   #1
Inertia question
Which is harder to rotate?
A rod with a mass (m1) in the center, or a rod with two masses (m2)at the ends.
Assume mass m1 = 2*m2, so the total masses of rod+masses are equal.
I am rotating the masses at the center.
My professor said that the one with the mass in the center is harder to rotate, but I dont understand how he explained it. I actually thought the one with the mass in the center was easier to rotate.
Can someone explain why the one with the mass in the center is harder to rotate?
Is it because if we were to rotate each to the same angular velocity, it would take more work to get the first rod to that angular velocity?
Relevant equations.
I think I'd use Kr = I [tex]\omega^{2}[/tex]
and if they go up to the same angular velocities, it requires more work?
It doesn't seem right, because if the I of the first rod is lower, so the Kr would be lower, so that means the work required to get it to that speed was lower?
I don't see why the one with the mass in the center is easier to rotate.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Nov15-07, 04:31 AM   #2
Recognitions:
Homework Helper Homework Help
assuming that you are rotating about an axis that goes thru the center then it would harder to rotate the m2 case because it has larger moment of inertia. unless i have misunderstood the setup.
torque = moment of inertia x angular acceleration
you may have mis-heard your prof.. or there are something else in the system?
Nov15-07, 04:57 AM   #3
Recognitions:
Quote by sagebum View Post
It wouldn't take any energy to rotate the rod with m1 in the centre, because the velo of the point mass at the centre would be zero.
Perhaps you misunderstood your professor, as mjsd says?
Nov15-07, 08:40 AM   #4
Inertia question
Yeah, I thought what u said was the answer too, I'll have to ask my professor again, maybe i switched up what he said.
Thanks for helping
Thread Closed
Thread Tools
Similar Threads for: Inertia question
Thread Forum Replies
question about the product of inertia Classical Physics 0
moment of inertia question Introductory Physics Homework 5
Rotational inertia question. Classical Physics 1
One more inertia question... Introductory Physics Homework 3
moment of Inertia of question Classical Physics 8
