Help Period of oscillation of the mass
The discussion centers on calculating the period of oscillation for a mass-spring system. The mass is displaced 0.16 m from its equilibrium position and at t = 0.50 s, it is 0.08 m from equilibrium. The position of the mass can be expressed as x(t) = A*cos(ω*t), with A set to 0.16 m and the phase φ set to 0. To find the period, the user must solve for angular frequency ω using the position at t = 0.50 s and then use the relationship between ω and the period (T = 2π/ω).
  • Understanding of harmonic motion principles
  • Familiarity with trigonometric functions and their applications in physics
  • Knowledge of angular frequency and its relationship to oscillation period
  • Basic skills in algebra for solving equations
  • Calculate angular frequency (ω) using the equation x(t) = A*cos(ω*t)
  • Determine the period of oscillation using the formula T = 2π/ω
  • Explore the effects of varying mass and spring constant on oscillation period
  • Study the concept of damping in oscillatory systems and its impact on period
Physics students, educators, and anyone interested in understanding the dynamics of mass-spring systems and harmonic motion.
andycl
A mass which is resting on a horizontal frictionless surface is connected to a fixed spring. The mass is displaced 0.16 m from its equilibrium position and released. At t = 0.50 s, the mass is 0.08 m from its equilibrium position (and has not passed through it yet).
What is the period of oscillation of the mass?
I know I am suppose to put what I have done so far but I have given up with the trying. Could somebody please give me some guidance and explain please.
Thank you!
You can generally write the position of the mass wrt to equilibrium as x(t)=A*cos(omega*t+phi), where A is the maximum displacement and phi is the phase. Since you know you have maximum displacement at t=0 you can set phi=0 and A=0.16m. So x(t)=(0.16m)*cos(omega*t). Enough hints, now can you put the values at t=0.5 sec in and solve for omega? Knowing omega, can you figure out the period?
