How Does Rotational Motion Affect a Cube and Pulley System?
The discussion focuses on the dynamics of a cube and pulley system involving a 500 g cube and a 50 g weight. The time to unwind 30 cm of string is calculated using the formula t = √(2L/(rα)), where L is the length of the string and r is the radius of the pulley. To find angular acceleration (α), participants are advised to apply Newton's second law to both the cube and the hanging weight, and to consider the relationship between linear and angular acceleration. For kinetic energy calculations, conservation of mechanical energy is recommended.
  • Understanding of Newton's second law
  • Familiarity with rotational inertia concepts
  • Knowledge of conservation of mechanical energy
  • Basic principles of rotational motion
  • Research how to calculate rotational inertia for a cube
  • Study the relationship between linear acceleration and angular acceleration
  • Learn about the derivation of the time unwinding formula t = √(2L/(rα))
  • Explore conservation of mechanical energy in rotational systems
Physics students, mechanical engineers, and anyone studying dynamics and rotational motion in mechanical systems.
Superfluous
A cube of mass M = 500 g and side length 30 mm is free to spin on an axis through the center of one face. A massless pulley on this axis has a diameter of 2r = 10 mm. A weight of m = 50 g is hung from a string wrapped around the pulley. The assembly is released from rest.
(a) Find the time to unwind L = 30 cm of string.
(b) Find the kinetic energy of the spinning block after the string unwinds, using energy methods.
I found a formula for time (I think):
[tex]t=\sqrt{\frac{2L}{r\alpha}}[/tex]
I have L and r, but how do I find alpha? And also, how do I go about solving part b? I'm a bit confused on what I need to take into consideration.
Do you know how this formula was derived?
You find alpha by applying Newton's 2nd law to both bodies (the cube and the hanging weight) and solving for the acceleration. (You'll have to look up the rotational inertia for a cube.) Start by identifying the forces acting on each. How does linear acceleration of the falling mass relate to the angular acceleration of the pulley (and cube)?
For part b, use conservation of mechanical energy.
  • · Replies 30 ·
  • · Replies 22 ·
