What is the formula for force on a falling rod as it tips past vertical?
The discussion revolves around deriving an equation for the force on a rod that is tipping past vertical while balancing on a table. The problem involves concepts from dynamics, particularly the forces acting on the rod as it falls and the conditions under which it remains in contact with the table.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the implications of the normal force and its relationship to the gravitational force as the rod tips. There are attempts to clarify the conditions under which the normal force changes and the role of friction. Questions arise regarding the validity of the derived equations and the assumptions made about the system.
The discussion is ongoing, with participants providing insights and hints about the relationships between forces and accelerations. Some participants have suggested alternative approaches, such as analyzing the problem in polar coordinates, while others are questioning the assumptions and calculations presented. There is no explicit consensus yet, but the dialogue is productive.
Participants note that the rod does not slip and that the problem involves a pivot point, which complicates the analysis of forces. There are references to the moment of inertia and angular acceleration, indicating that these factors are under consideration in the derivation of the equations.
kataya
Suppose there is a rod balancing on a table. The rod tips past vertical and begins to fall. Derive an equation for the force on the bottom of the rod as a function of the angle between the rod and the table. Assume that the rod does not slip, even if this implies a very large coeffecient of static friction.
The rod has length L and mass M. Its mass is evenly distributed along its length.
sum of forces, sum of moments. Parallel axis theorem.
Here is a free body diagram of the rod/table.
http://www.prism.gatech.edu/~gtg857w/PforumMisc.bmp
Taking the sum of the forces in the vertical direction yields:
N = M(a + g). a is the vertical acceleration of the center of mass.
This doesn't make any sense to me, because it seems to be implying that the pendulum is falling faster than under free fall! How can this be? I know that the normal force is non-zero because the force of friction must counteract the moment caused by it (in order to not slip at the point of rotation) but why on Earth is it greater than g?
It's not.
What is the force when it is upright? [tex]N=mg[/tex]
What is the force when it is lying down? [tex]N=0[/tex]
So at any angle, the force will be between 0 and mg.
Yes that makes sense intuitively, but it does not explain why the summation of forces in the vertical direction gives the wrong answer. Please expand your response to include Newton's laws or another aptly derived relation. Thank you for your reply.
-Tyler
Regarding your remark about N: your acceleration is negative, since
[tex]ma_x = +N -Mg[/tex]
leads to the conclusion [tex]a_x<0[/tex], as N<Mg. Hence a+g<g.
Regarding the problem: here is a hint. The table is meaningless. You are describing the rotation of a pendulum released from an inverted position, since you only have one point of contact (a pivot). The normal force only tells you "half the tale", mind you, as there is also a force (in this case friction) that also constraints the rod in the y-direction. So saying "N=0, N=Mg" isn't enough to understand what's going on.
Assaf.
http://www.physicallyincorrect.com/"
In the vertical, the forces are [tex]N=mg[/tex]
At any angle, the force is [tex]N=mgsin{\theta}[/tex]
The end of the rod does not move.
Therefore acceleration on the end of the rod is always 0.
Therefore, the net force on the end of the rod is always 0.
Therefore, see post #5.
WOW that's embarrassing.
I believe I can derive the rest of the relation.
Bill Foster, the sum of forces on a solid body is equal to the product of the mass and acceleration of the center of mass of the body. You can't just sum it up at a point and say that point isn't moving if it's part of a larger body.
Anyways, thank you ozymandias for pointing out that the acceleration is negative. This gives the relation:
[tex]N = m(g - a)[/tex]
a here is the component of the acceleration in the vertical direction, which is also equal to:
[tex]\frac{L\alpha}{2}cos(\theta)[/tex]
If you put this into a above, you get
[tex]N = m(g - \frac{L\alpha}{2}cos(\theta))[/tex]
Where alpha is the angular acceleration of the rod's center of mass.
Don't sweat it, I have made much worse mistakes in my career :smile:
At any rate, you should let the "mathematical machinery" take care of minus signs. Newton's 2nd law for the CM, once we agree "up" is "positive", is:
[tex]MA = +N - Mg[/tex]
or:
[tex]N = M(A+g)[/tex]
You should just keep in mind that A can be both negative and positive.
The angular acceleration doesn't simplify your problem because it is also (1.) unknown, (2.) not a constant. You need to derive an expression for it using the other constants of your problem.
Hint: it makes much more sense (to me) to analyze this problem in polar coordinates, since in such coordinates the force exerted by the pivot is always central, which makes the tangential part easy to solve.
Hint #2: write the (CM) acceleration in polar coordinates - look at Kleppner & Kolenkow if you have it, p. 36.
Good luck :smile:
Assaf.
A few additions/corrections, and so we can maybe add the *solved* tag:
[tex]\alpha[/tex] in the previous equation was the angular acceleration of the rod about its pivot point. Not about the center of mass.
The sum of the moments on the rod about the point of rotation will give alpha.
[tex]\alpha = \frac{1}{I}[Mgcos(\theta)][/tex]
So the entire equation becomes:
[tex]N = Mg(1 - \frac{ML}{2I}cos^{2}(\theta))[/tex]
Where I is the moment of inertia of the rod spinning about its end.
This does not give N = 0 for theta = 0, which seems wrong, but perhaps it is legit.
Check my work anyone?
  • · Replies 39 ·
  • · Replies 31 ·
