Does Increasing Differentiable Function Always Have Positive Derivative?
  • Thread starter Thread starter asif zaidi
    Differentiation
The discussion revolves around the properties of differentiable functions, specifically focusing on whether an increasing differentiable function must have a non-negative derivative across its domain.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • The original poster attempts to use the definition of differentiation to argue that the derivative of an increasing function is non-negative. Some participants question the correctness of the definitions and sequences used in the argument. Others suggest using the Mean Value Theorem as a simpler approach.
The discussion is ongoing, with participants providing feedback on the original poster's reasoning and suggesting alternative methods. There is no explicit consensus, but various interpretations and approaches are being explored.
Participants are addressing potential misunderstandings in the definition of differentiability and the implications of the Mean Value Theorem. There is a focus on ensuring the correct application of mathematical definitions and theorems.
asif zaidi
Problem statement
Show that if F:(a,b)->R is differentiable at every point of (a,b) and increasing then f'(x) >= 0 for all x belonging to (a,b)
Problem Solution
Definition of differentiation:
Assume sequence {an} -> a then
f(an) - f(x) / (an -x) converges to some value
Using this definition I am saying since it is known that f is differentiable at a,b then the following is true
Assume sequence an->a and bn->b
then f(bn) -f(an) / (bn-an) --- (eq1)
Since this is an increasing function both numerator and denominator will be always greater than 0 and thus the derivative by eq1 is always positive.
Am I on the right track?
If not please advise.
Thanks
Asif
I think you meant [f(b) -f(bn)] / (b-bn) and alternatively [f(an) -f(a)] / (an-a). Even then this only addresses f'(a) > 0 and f'(b) > 0.
No I meant what I had written - however I did realize after posting that it was wrong. I worked through a specific f(x) and figured it was wrong.
If I use the definition of differentiability as you have done (f(b) - f(bn))/(b-bn), can I safely say that it is f'(b) >= 0;
Is that really the definition of "differentiation" your text gives?
It should be "f is differentiable at a if and only if for every sequence {an} that converges to a, (f(an)- f(a))/(an-a) converges to the same limit. If f is differentiable at a, then its derivative is that common limit."
(NOT "f(an) - f(x) / (an -x)" that makes no sense. You must mean (f(an)- f(a))/(an-a) with "a", not "x". )
The way you've written it, it sounds like just one such sequence would be sufficient to determine that a function is differentiable. Of course, here, since you are given that f is differentiable, then it really doesn't matter.
I see no reason for looking at two sequences {an} and {bn}. Take {an} to be a sequence converging to a with an> a for all n.
asif zaidi said:
Problem statement
Just use mean-value theorem.
Well, if you want to do things the easy way! :)
