| Thread Closed |
specific heat of a piece of metal dropped in water |
Share Thread | Thread Tools |
| Nov16-07, 02:18 PM | #1 |
A metal container, which has a mass of 8.0 kg contains 14.3 kg of water. A 2.9-kg piece of the same metal, initially at a temperature of 190.0°C, is dropped into the water. The container and the water initially have a temperature of 15.1°C and the final temperature of the entire system is 17.1°C. Calculate the specific heat of the metal. 2. Relevant equations Q = c* m *change in T 3. The attempt at a solution The heat of the container + the heat of the water = the heat of the piece of metal using algebra I got the equation: cwater*Mwater*change in Twater / [Mpiece*change in Tpiece - Mcontainer*change in Tcontainer] I am having trouble figuring out the temperatures for the equation. Please help! |
| Nov16-07, 02:42 PM | #2 |
Recognitions:
Nearly right, The change in T for the container and the water is the same.
So the equation is Cwater * Mwater * dT water + Cmetal * MContainer * dTwater = Cmetal * Mmetal *dTmetal The only unknown is Cmetal. |
| Nov16-07, 02:45 PM | #3 |
Recognitions:
Hi cyclonefb3,
There's no equality sign in your eqn. Let t be the final temp. Then, (14.3*Cw+8*Cm)(17.1-15.1) = (2.9*Cm)(190-17.1). If Cwater is known, you can find Cm. |
| Nov16-07, 02:51 PM | #4 |
I think I have the dTpiece wrong this is what i'm entering:
41.86(14.3)(17.1-15.1) / [2.9*(190-15.1)] - [8*(17.1-15.1)] I'm not sure where to go from here... |
| Nov16-07, 03:01 PM | #5 |
Recognitions:
It would help if your equations had = signs!
Cwater * Mwater * dT water + Cmetal * MContainer * dTwater = Cmetal * Mmetal *dTmetal 4200 * 14.3 (17.1-15.1) + C * 8 (17.1-15.1) = C * 2.9 (190-17.1) 120120 = C (2.9*172.9 - 8*2) Hint C for metals is generally a few hundred J/kg/k |
| Nov16-07, 03:02 PM | #6 |
thanks, it was just he program being really picky with digits.
| Thread Closed |
| Thread Tools | |
Similar Threads for: specific heat of a piece of metal dropped in water
| [SOLVED] Quantity of Heat/Specific Heat Water+Iron | Introductory Physics Homework | 3 | ||
| Specific heat of certain hard water(hardness measured with gpg) | General Physics | 0 | ||
| Specific Heat of a Metal | Introductory Physics Homework | 2 | ||
| specific heat ratios of water, air, and related questions | Introductory Physics Homework | 1 | ||
| Why does water have a high specific heat? | Chemistry | 1 | ||
