Estimating \int_{0}^{1/2}\frac{1}{\sqrt{1+x^3}}dx using Power Series
The discussion revolves around estimating the integral \(\int_{0}^{1/2}\frac{1}{\sqrt{1+x^3}}dx\) using power series, with a focus on achieving an accuracy of within \(10^{-3}\). Participants explore the application of the binomial series and the integration of power series, while also addressing error estimation techniques without the use of calculators.
  • Homework-related
  • One participant expresses confusion about using power series to estimate the integral and questions the validity of their approach using the binomial series.
  • Another participant suggests that the integration of the power series needs to be performed and discusses how to estimate the error of the integral.
  • A participant clarifies that the integration has been done correctly but emphasizes the importance of estimating the error associated with the integral of the remainder.
  • Further clarification is provided regarding bounding the integral of the error by considering the supremum of the function over the interval.
  • One participant seeks clarification on how to determine the number of terms \(n\) needed to achieve the desired accuracy in the estimation.
  • A later reply introduces the concept of using Taylor expansion and discusses the derivatives of the function to find a bound for the error in the integral.
  • Another participant proposes a substitution \(x^3 = u\) as an alternative method to simplify the problem and make derivative calculations easier.
Participants do not reach a consensus on the best approach to estimate the integral or the specifics of error estimation. Multiple competing views and methods are presented, and the discussion remains unresolved regarding the most efficient technique.
Participants express uncertainty about the error bounds and the appropriate number of terms to use in their series expansion. There are also references to the complexity of derivative calculations and the potential for alternative methods that have not been fully explored.
AngelofMusic
Hi,
This was a question on a past exam, and I'm very confused about how to do this. We're not allowed calculators, so I'm sure there must be some simple solution that I'm missing.
It asks: Use power series to estimate [tex]\int_{0}^{1/2}\frac{1}{\sqrt{1+x^3}}dx[/tex] within 10^-3.
I started off with the binomial series:
[tex](1+x^3)^{-1/2} = \sum_{k=0}^{\infty}\left(\begin{array}{ccc}<br /> -1/2 \\<br /> k \end{array}\right)x^{3k}[/tex]
I then integrated from 0 to 1/2 to get:
[tex]\int_{0}^{1/2}(1+x^3)^{-1/2}dx = \sum_{k=0}^{\infty}\left(\begin{array}{ccc}<br /> -1/2 \\<br /> k \end{array}\right)\frac{(1/2)^{3k+1}}{3k+1}[/tex]
Now I'm stuck because I don't know how to make it accurate within 0.01. The remainder has a formula:
[tex]R_n(x) = \frac{f^{(n+1)}(c)}{(n+1)!}x^{n+1}[/tex]
But I don't know how to find M, such that [tex]f^{(n+1)}(c)<=M[/tex].
Did I do this one completely wrong? Is there a power series that's easier to work with than the one I came up with? To me, it seems almost impossible to do this question without a lot of tedious work and using a calculator, but our exam is strictly no calculators allowed.
Any help would be appreciated!
The series you have there is for the function inside the integral. You still need to do some integration. You can estimate the error because, say, the integral of g over the interval [0,1/2] is no more than 1/2 sup g(x), where g is some positive function.
So you can do the integration of the powers of x, and get an estimate of the integral of the remainder.
But I thought I did the integration already?
[tex]\int_{0}^{1/2}\sum_{k=0}^{\infty}\left(\begin{array}{ccc}-1/2 \\k \end{array}\right)x^{3k} = \sum_{k=0}^{\infty}\left(\begin{array}{ccc}-1/2 \\k \end{array}\right) \int_{0}^{1/2}x^{3k}dx[/tex]
And that is [tex]= \sum_{k=0}^{\infty}\left(\begin{array}{ccc}-1/2 \\k \end{array}\right)\frac{(1/2)^{3k+1}}{3k+1}[/tex]
you did, i misread, but the thing about being able to estimate the error is still valid:
proper integral - integral; of first n terms = integral of error
l
integral of error can be bound by 1/2 sup possible error.
ie take the worst cas scenario
Sorry to be a bother, but I'm really unclear on this error bounds stuff. Can you explain what you mean by the phrase "integral of error can be bound by 1/2 sup possible error"?
Do you mean that I should do something like:
[tex]\sum_{k=0}^{\infty}\left(\begin{array}{ccc}-1/2 \\k \end{array}\right)\frac{(1/2)^{3k+1}}{3k+1} - \sum_{k=0}^{n}\left(\begin{array}{ccc}-1/2 \\k \end{array}\right)\frac{(1/2)^{3k+1}}{3k+1} = 0.001[/tex]
? If so, how do I go about figuring out what n is supposed to be from that?
Let me do it this way, the detail is annoying to type but I think I can't avoid it.
Let f be the function, f_n the taylor expansion up to the n'th term
[tex]f(x) - f_n(x) = R_n(x)[/tex]
where
[tex]R_n= f^{(n+1)}(c)x^{n+1}/n![/tex]
what are the derivatives of f? what is the maximal value of the n'th derivative? It should be quite small, and you can get any bound that works. Call this number M.
then the error in the integral is
M/(n+1)! times the integral of x^{n+1} between 0 and 1/2 which is intself quite small, so just find an n to make it as small as you want.
Alternatively you could have just made the substitution x^3 = u in the original integral and it would make it a lot easier - the derivatives would be so much easier to work out.
