Calculating Acceleration and Resistance in Motion: A Scientific Inquiry
The discussion revolves around two physics questions related to calculating acceleration and resistance in motion. The first question involves a body acted upon by gravitational and horizontal forces, while the second concerns the air resistance on a body in free fall.
  • Participants explore assumptions regarding gravitational acceleration values and question the completeness of the provided information. Some suggest using kinematic equations and vector analysis, while others express uncertainty about the nature of the questions, considering them potentially tricky.
The discussion is ongoing, with participants offering various interpretations and approaches. Some guidance has been provided regarding the use of equations and assumptions, but there is no explicit consensus on the questions' clarity or the necessary information.
Participants note potential ambiguities in the wording of the problems, particularly regarding the gravitational acceleration value and the implications of air resistance in free fall. There is also mention of the possibility of trick questions, which adds to the uncertainty in the discussion.
wikidrox
Can someone help me with these two questions:
1. a body of mass 2.0 kg is acted on by a downward force of gravity and a horizontal force of 40N. Find it's acceleration and velocity as a function of time, assuming it starts from rest.
2. Find the resistance of the air to the motion of a body of 4.0kg in free fall with a gravitational acceleration of 9.2m/s^2.
I feel there is not enough information to answer these.
You should assume some value for the gravitational acceleration. Usually, the standard value is 9.8 m/s2. You can use the kinematical equation to get the velocity.
#2
This sounds like one of two things: 1) not enough info., or 2) a trick question. Do you usually get trick questions?
1. The block goes 80ms^-2 to the right (let's say), and goes 9.8ms^-2 downwards. Use the pythagorian thereom to find its resulting acceleration. By finding the velocity in function of time they might want you to draw a graph... good luck, I hate doing those.
2. Objects in free fall eventually stop accelerating downwards when they reach a high enough velocity. So, at that point the resistance would be 9.2ms^-2 times 4kg.
Unless I'm missing something, that should be it.
Do you usually get trick questions?[/QUOTE]
Sometimes. But I don't see how it can be a trick question.
I don't see anything very tricky about them. Number 1 is a straightforward vector problem. The only thing "tricky" is the wording: "a gravitational acceleration of 9.2m/s^2." Did the problem really say that or did it say something like "falling under gravity the acceleration is 9.2 m/s2? The point is that gravitation acceleration (on the surface of the earth) approximately 9.8 m/s2 because the force of gravity is 9.8 times the mass. If the body is falling with acceleration 9.2 m/s2 then there is a net force of 9.2 times the mass. The air resistance force is (9.8- 9.2)= 0.6 times the mass. Since the mass is given as 4.0 kg, the force of air resistance is 0.6(4)= 2.4 Newtons.
But I still don't understand how to get the velocity.
Newtons 2nd:
F = ma
Constant acceleration motion:
V(t) = V0 + a*t
Give it a shot and let us know if and where you get stuck.
  • · Replies 16 ·
  • · Replies 28 ·
  • · Replies 39 ·
  • · Replies 35 ·
