Water psi effect on boat transducer
The discussion centers on the impact of water pressure (psi) on boat transducers, specifically those designed with an egg-shaped, elliptical profile to minimize drag. The user seeks to understand the water forces acting on a transducer face surface of approximately 2 square inches as boat speed increases from 10 to 80 mph. While various factors such as salinity and current influence these forces, a simplified approach suggests modeling the transducer as a flat plate for initial calculations, despite this yielding higher force estimates. The user emphasizes the need for a straightforward explanation due to a lack of physics background.
  • Understanding of fluid dynamics principles
  • Familiarity with boat transducer designs and their purposes
  • Basic knowledge of pressure calculations in relation to speed
  • Awareness of drag reduction techniques in marine applications
  • Research fluid dynamics and pressure calculations for moving objects
  • Learn about the design and function of various types of boat transducers
  • Explore drag reduction techniques specific to marine vessels
  • Investigate simulation tools for modeling fluid forces on submerged objects
Marine engineers, boat designers, and hobbyists interested in optimizing transducer performance and understanding the effects of water pressure on submerged objects at varying speeds.
captain chris
I am seeking a general answer relative to boat speed and psi effect on a transducer. I understand many variables affect this, ie, salinity, current, etc. Assuming a transducer mounted on the back of a boat hangs below into the water 1/4", water forces increase against this object as boat speed increases. The transducer is purposely 'egg-shaped" and mounted longitudinally to reduce drag. I am seeking round-about psi water force on the face surface of the transducer of approximately 2" sq (max), in 10 mph increments from 10 to 80mph. I am looking for a backup theory to assist in substantiating what I now believe to be somewhat accurate. There is likely no way to compute accurately, but close is workable. I am not schooled in physics, so, the simpler the better. Thanks!
What kind of transducer are you referring to? What is the purpose of the transducer? Without an exact shape, the only quick and dirty way to calculate the forces acting on that would be to simulate it as a flat plate which will give you higher forces and thus be inaccurate.
boat transducer shape
Fred,
The shape is commonly elliptical, to facilitate lessening drag. I believe I likened it to an "egg'shape". Just picture maybe 1/4 of an egg below the bottom at the stern of a boat dragging in the water 1/4" below the bottom. The 'egg" (or transducer) would be positioned where the ergonomic ends would point fore and aft. It could be any kind of transducer for sonar, or camera, or maybe microphone, but would trail behind a boat at float or at a faster speed as I have indicated. Thanks!
  • · Replies 20 ·
  • · Replies 24 ·
  • · Replies 26 ·
  • · Replies 32 ·
14K
