Convection & Shapes: How Would They Affect Heat Plate?
  • Thread starter Thread starter Hollysmoke
    Convection
This discussion focuses on the impact of various shapes on convection in a vertical tube heat plate setup. The shapes analyzed include a heat plate with no obstruction, a bundle of tubes, and fins. The key takeaway is that flow lines downstream of an obstacle, such as tubes with diameter d, return to a homogenized state within a distance comparable to d. Additionally, specific shapes like tear-drop can significantly alter this distance, affecting convection efficiency.
  • Understanding of convection principles
  • Familiarity with fluid dynamics concepts
  • Knowledge of heat transfer mechanisms
  • Basic geometry of shapes and their impact on airflow
  • Research the effects of different shapes on airflow patterns in fluid dynamics
  • Explore computational fluid dynamics (CFD) tools for simulating convection
  • Study the impact of surface area and shape on heat transfer rates
  • Investigate the use of fins in enhancing heat dissipation in thermal systems
This discussion is beneficial for engineers, thermal system designers, and researchers focused on optimizing convection in heat transfer applications.
Hollysmoke
Hi, I was wondering if someone could help explain how the following shapes would affect convection. What it is is a heat plate with nothing, a bundle of tubes, and just fins. It's in a vertical tube and the air flows upwards. I understand convection but I don't get how it would be affected in terms of a physical object such as these in its path.
http://img231.imageshack.us/img231/718/heatplatesf1.jpg
The rule of thumb I use is that flow lines just downstream of an obstacle get very close to their far-away away structure within a distance comparable to the width of the obstacle. So if the tubes have a diameter d, then at a distance d downstream from each tube, the flow-lines are essentially homogenized again. For some shapes (tear-drop, for instance), this distance can be much smaller than the width of the object.
  • · Replies 34 ·
  • · Replies 19 ·
