Thread Closed
max Height
Share Thread Thread Tools
Nov18-07, 02:34 PM   #1
max Height
A .050-kg ball is shot at a velocity of 12 m/s by an upward-slanting cannon. At its maximun height, the kinetic energy of thew ball is 24J.
a) Tha max. height is?
b) the angel of the cannon to the horizontal is?
I really dont know where to start on this question. If someone can give me the equation I should used, I can go from there. I am thinking that I have to work backwards using the kinetic energy.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Nov18-07, 02:59 PM   #2
ok, this is what i figured out so far
mgh=1/2mv^2 which m can cancel out gives gh-1/2v^2 which can give me h which is
h= v^2/2g which I can solve for is 12^2/ 2*9.87m/s = 7.3m
is this right?
Nov18-07, 03:08 PM   #3
Recognitions:
Homework Helper Homework Help
If b is the angle in radians of the cannon to the horizontal, then the initial velos ux=12cos b,and uy = 12sin b. The horznt comp ux = vx remains const. At the highest pt, all the kinetic energy is just 0.5*m*vx^2, which gives you vx^2.
From that, you can find uy^2, by considering the initial speed.
If initial vert velo is known, you can find the max height, and tan b can be found from uy and ux.
I have perhaps given too much of detail.
Nov18-07, 03:20 PM   #4
max Height
ok, i found the max height already, and it was 7.3.
So I think you are saying that using that i can find the angle b , using what equation?
Nov18-07, 04:00 PM   #5
Ok ,
what about this equation
24J= 12cos(degree)
can i set it up like this to find the answer , if so is the answer 66degrees.
Nov22-07, 12:01 PM   #6
Recognitions:
Quote by NewJersey View Post
That's not correct. (Check the data you have given -- doesn't make sense.)
Did you understand what I had said in my earlier post? If not, tell me which portion you didn't understand. I think you should thoroughly revise projectile motion once before attempting problems.
Thread Closed
Thread Tools
Similar Threads for: max Height
Thread Forum Replies
Help w/Max height Introductory Physics Homework 2
height Biology 5
Height Biology 2
Height... General Discussion 56
Height General Discussion 73
