Thread Closed
Rotational Motion and Angular Displacement
Share Thread Thread Tools
Nov19-07, 10:31 PM   #1
A stroboscope is a light that flashes on and off at a constant rate. It can be used to illuminate a rotating object, and if the flashing rate is adjusted properly, the object can be made to appear stationary.
(a) What is the shortest time between flashes of light that will make a three-bladed propeller appear stationary when it is rotating with an angular speed of 12.6 rev/s?
(b) What is the next shortest time?
2. Relevant equations
ω=(∆θ)/(∆t)
3. The attempt at a solution
I took ∆θ = ⅓ rev (2pi radians/1 rev) = 2.09 radians
then I used ω=(∆θ)/(∆t)...
12.6 = (2.09/t) which gives me t=.166
What I did makes sense to me, but the answer is wrong so obviously I am too...Don't know what else to do...
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Nov19-07, 10:36 PM   #2
Looks like you have an issue with unit consistency. You have put the angular displacement in radians, but the angular velocity is in rev/s. Change velocity to rad/s.
Nov19-07, 10:41 PM   #3
i'm retarded....
THANKS!!!
Nov19-07, 11:04 PM   #4
Quote by wchvball13 View Post
i'm retarded....
No, no...don't be so hard on yourself. I like to refer to these moments as "Brain Farts". Not quite as permanent!
Thread Closed
Thread Tools
Similar Threads for: Rotational Motion and Angular Displacement
Thread Forum Replies
conceptual question about angular speed and radius for rotational motion General Physics 5
Yo-Yo Question - Rotational motion/angular momentum Introductory Physics Homework 1
Angular Displacement in Rotational Dynamics Classical Physics 2
Rotational motion -angular energy+angular acceleration Introductory Physics Homework 4
Rotational Motion/Angular Momentum Introductory Physics Homework 1
