Thread Closed
Lorentz Invariance and Non-Galilean Invariance of Maxwell's Equations
Share Thread Thread Tools
Nov21-07, 07:57 PM   #1
I am having trouble going about proving the Lorentz invariance and non-Galilean invariance of Maxwell's equations. Can someone help me find a simple way to do it? I've looked online and in textbooks, but they hardly give any explicit examples.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Nov21-07, 08:11 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
You have to specify how the fields transform.
To do it in general, it's easiest to do it tensorially.
You could do it vectorially... or possibly less elegantly component-wise.
Can you show some of your attempts so far?
Nov24-07, 01:02 PM   #3
I've tried transforming the coordinates of the wave equations for Maxwell's equations into Lorentz transformed equations via the x and t components, excluding the y and z components of the wave equation for simplicity. I figuredsince the equations are homogeneous, the x and t components should be either equal to each other or each equal to zero when taking the second derivatives of each component (since the x - t components equal zero). I received a very messy x components after partially differentiating it twice, and noticed that the electric field doesn't have a time component in it, so it should equal zer, but I didn't see how my differentiated x part could equal zero too. Is this a good way to go about it? With the wave equations, substitute in the transformed coordinates? Otherwise, I've started the tensor formation that you said, with the field strength and the dual tensors, I derived Maxwell's equations via the four-vectors of current and potential. I figured I could simply transform the field strength tensor and the dual tensor each by Lorentz transformation matrices, then take those transformed tensors and try to derive Maxwell's equations by the same previous method, and receive the same result. But, I was confused as to what transformation matrices to use on the tensors, since they are second-rank tensors. What matrices would I use? Which way is better, if either of them are good?
Nov26-07, 04:51 PM   #4
Recognitions:
You can show that the 1+1 wave equation is not invariant under a Galilean-boost. [Take care with the Chain Rule.]
It is invariant under a Lorentz-boost (as suggested by the d'Alembert form of the solution). [Use the d'Alembert form and light-cone coordinates.]
The calculations in terms of components are tedious. It's worth doing explicitly... then doing it tensorially.
I don't have the patience right now to [tex]\LaTeX[/tex] the steps in this exercise. It might be best if you show your explicit steps, which we can comment on. You might find some help from
http://farside.ph.utexas.edu/teachin...res/node6.html
http://www2.maths.ox.ac.uk/~nwoodh/sr/index.html
Nov27-07, 03:13 AM   #5
Recognitions:
Dahaka,
Have a look here. I managed to boost (Lorentz transform) the F tensor after some help.
http://www.physicsforums.com/showthr...2&goto=newpost
Thread Closed
Thread Tools
Similar Threads for: Lorentz Invariance and Non-Galilean Invariance of Maxwell's Equations
Thread Forum Replies
[SOLVED] invariance of maxwell's equations under Gauge transformation Advanced Physics Homework 6
Show Lorentz invariance for Euler-Lagrange's equations- how? Special & General Relativity 4
Tensors: Lorentz vs Galilean invariance Special & General Relativity 1
Galilean invariance (and Maxwell's equations) Classical Physics 7
Schroedinger Equation - Galilean Invariance Quantum Physics 5
