What Factors Influence Peroxidase Activity in Hydrogen Peroxide LAB Analysis?
  • Thread starter Thread starter mickeyminnie
    Lab
The discussion focuses on the factors influencing peroxidase activity in hydrogen peroxide lab analysis, specifically examining the effects of temperature, pH, alcohol, and saline solutions. Key variables identified include dependent (peroxidase from potato), independent (hydrogen peroxide), and controlled (distilled water). The optional temperature range for peroxidase is not explicitly stated, but comparisons are drawn with catalase activity, which operates optimally at 36-37 degrees Celsius and pH 6.5 to 7.0. Participants emphasize the importance of measuring hydrogen peroxide's spontaneous decomposition to understand enzyme activity accurately.
  • Understanding of enzyme kinetics and peroxidase function
  • Familiarity with laboratory procedures for measuring enzyme activity
  • Knowledge of the effects of temperature and pH on enzyme stability
  • Basic skills in experimental design and data analysis
  • Research the optimal temperature and pH ranges for peroxidase activity
  • Learn about the impact of inhibitors and activators on enzyme reactions
  • Explore methods for measuring enzyme activity, such as spectrophotometry
  • Investigate common sources of error in enzyme activity experiments
Students conducting enzyme activity experiments, educators teaching biochemistry, and researchers interested in enzyme kinetics and laboratory methodologies.
mickeyminnie
Analysis:
What are the effects of various temperature, pH, alcohol, and saline solution treatments on peroxidase activity?
What are the optional ranges of temperature and pH for peroxidase? Are alcohol and saline solution inhibitors or activators?
Sate the dependent, independent and controlled variables in this investigation
My answer:
Dependent- peroxidase (potato)
Independent – hydrogen peroxide
Controlled variable - distilled water
Why should hydrogen peroxide’s spntneous decomposition into gaseous oxygen be measured in the absence of any enzyme?
What is the significance of the other data be if this datum were not gathered?
Inquiry Skills:
Evlalute the procedure by identifying sources of error and suggesting any modifications to the method you designed that you feel would improve the accuracy and precision of the data.
Knowledge:
Question 5: Sate the optional range of temperature and pH for peroxidase.
Questions 6: The optional temperature and pH ranges of catalase are known to be 36-37 degree at a pH of 6.5 to 7.0. how does this profile compare with what you found for peroxidase in question#5?
I'm completely lost in this lab. I don't get proper help from my teacher since its a distance education course. Please someone help with this lab. I want HINTS
Without more details about your experiment, I can't really evaluate your answers at all to offer help.
I'm also assuming the answers are intended to be based on your actual data while conducting the lab. If you show some of that data, we might be able to help give you pointers.
11K
15K
32K
  • · Replies 28 ·
