Is Griffith's Treatment of Spin in Quantum Mechanics Misinterpreted?
Griffith's treatment of spin in quantum mechanics distinguishes between orbital angular momentum and intrinsic spin. The operator for orbital angular momentum, represented as -\hbar^2 (1/sin(θ) ∂/∂θ (sin(θ) ∂/∂θ) + 1/sin²(θ) ∂²/∂φ²), only admits integral eigenvalues, thus excluding half-integral values when parametrized in terms of angles. Spin and orbital angular momentum both satisfy the same commutation relations, but they are fundamentally different; spin is represented by matrices in an internal space, while orbital angular momentum is represented by differential operators in physical space.
  • Understanding of quantum mechanics concepts, specifically angular momentum.
  • Familiarity with Griffiths' "Introduction to Quantum Mechanics".
  • Knowledge of differential operators and their application in quantum mechanics.
  • Basic understanding of commutation relations in quantum theory.
  • Study the mathematical representation of angular momentum in quantum mechanics.
  • Learn about the differences between intrinsic spin and orbital angular momentum.
  • Explore the implications of commutation relations on quantum states.
  • Investigate the role of differential operators in quantum mechanics, particularly in Griffiths' framework.
Students of quantum mechanics, physicists specializing in quantum theory, and educators seeking to clarify the distinctions between spin and angular momentum in quantum systems.
lion8172
I have a question relating to Griffith's treatment of spin. Griffiths shows, using the commutation relations for angular momentum, that L^2 has eigenvalues l(l+1), where l=0, 1/2, 1, 3/2, ... He also shows that the operator
[tex]-\hbar^2 \left( \frac{1}{\sin(\theta)} \frac{\partial}{\partial \theta} \left( \sin(\theta) \frac{\partial}{\partial \theta} \right) + \frac{1}{\sin^2(\theta)} \frac{\partial^2}{\partial \phi^2} \right)[/tex]
only admits eigenvalues with integral values of l, by directly solving the differential equation. At one point, he states that the above expression is equal to L^2. My question is as follows: Is it correct to state that the half-integral eigenvalues are automatically excluded when L^2 is parametrized in terms of angles, and is it true to state that L^2 is not, in general, equal to the expression above? Spin and angular momentum satisfy the same commutation relations, so would it be correct to state that "angular momentum" is a kind of "spin" which is generated by an operator of the form [tex](\hbar/i) (\vec{r} \times \nabla)[/tex]?
Yes, what you say is basically correct. The language people use is slightly different, however. What you call angular momentum (represented as a differential operator acting in space) should be called "orbital angular momentum". What you call spin for the more general concept is usually called "angular momentum".
SO spin and orbital angular momenta are two types of "angular momentum". Spin is also called "intrinsic" angular momentum and is represented by matrices acting in an internal space. Orbital angular momentum is represented by differential operators acting in ordinary space.
  • · Replies 0 ·
  • · Replies 21 ·
