Investigating the Dependence of SoS on Pressure & Temperature
  • Context: Graduate
  • Thread starter Thread starter RKT
    Pressure Temperature
The speed of sound (SoS) in a gas is primarily dependent on temperature, as established in the discussion. The first case presented demonstrates that in a poorly conducting cylinder, increased temperature from compression raises SoS due to higher molecular velocities. Conversely, in a well-conducting cylinder, heat loss equalizes the internal and external temperatures, suggesting that SoS remains constant. However, the discussion highlights that for real gases, density can also influence SoS, challenging the notion of pressure independence in certain scenarios.
  • Understanding of thermodynamics principles, particularly gas behavior.
  • Familiarity with the concept of speed of sound in gases.
  • Knowledge of ideal versus real gas distinctions.
  • Basic principles of heat conduction in materials.
  • Research the relationship between speed of sound and density in real gases.
  • Explore thermodynamic properties of gases under varying pressure and temperature conditions.
  • Study the effects of heat conduction in different materials on gas behavior.
  • Investigate the mathematical models describing SoS in both ideal and real gases.
Physicists, engineers, and students studying thermodynamics or acoustics, particularly those interested in the behavior of gases under varying conditions of pressure and temperature.
RKT
SoS again ...
Hiya ,
The commonly held view is that speed of sound (SoS) in a gas depends on temperature and not pressure. I want to know if this is always true. Consider the following two cases and let me know what you think.
In the first case, we have cylinder made of a bad conductor of heat such some strong plastic or something. The gas is compressed in the cylinder. Here the temperature will rise and the heat more or less is confined to the cylinder. SoS will be higher than at normal temp. as the increased temperature results in higher molecular velocities inside the cylinder. Fair enough.
In the second case, the cylinder is made of a good conductor such as a metal. Here the heat of compression will lost to the surroundings within a few minutes. The temp. inside the cylinder will be the same as the outside temp. by then. Theory says that since the temp. is the same, the SoS inside will the same as outside.
My question : For the second case, given that the molecules are packed much more closely than at atmospheric pressure, won't any disturbance (sound) propagate quicker than at atm. pressure ? When I researched the dependence of SoS of a gas on temp. and pressure on the net, I observed that writers always cite the behavior of sound in the Earth's atmosphere as proof of independence of pressure on SoS. To my mind, this is not a good example because this looks like just one particular case where pressure indeed has no bearing. In the atmosphere a change in pressure usually means a change in temp. as well and vice versa so one need not consider the two separately.
Regards
RT
Science news on Phys.org
RKT said:
Hiya ,
Only true for an ideal gas - a real gas it depends on temperature (mostly) and density (slightly)
  • · Replies 0 ·
  • · Replies 35 ·
  • · Replies 28 ·
  • · Replies 20 ·
