Friction and Forces - Find Range of Values for P on a 30deg Plane
  • Thread starter Thread starter Trail_Builder
    Forces Friction
The problem involves a block of mass 10kg on a rough inclined plane at 30 degrees. A horizontal force P is applied, and the task is to determine the range of values for P that will keep the block stationary, given a coefficient of friction of 0.4.
  • Participants discuss the components of forces acting on the block, including weight, normal reaction, and friction. Questions arise regarding the assumptions about the direction of the friction force and the normal force. Some participants suggest that equilibrium of forces is necessary for the block to remain stationary.
The discussion is ongoing, with participants clarifying assumptions and exploring the conditions for equilibrium. There is a focus on the relationship between the forces acting down the plane and those resisting motion, though no consensus has been reached on the specific range of values for P.
Participants express uncertainty about their assumptions regarding the forces involved, particularly the direction of the friction force and the normal reaction. The problem is framed within the constraints of a homework assignment, which may limit the information available for discussion.
Trail_Builder
A block of mass 10kg on a rough plane inclined at 30deg to the horizontal. A horizontal force P acts on the block. The coefficient of friction between the block and the plane is 0.4, and it is sufficiently small for the block to slide down the slope if P does not act. Find the range of possible values of P if the block remains stationary.
Ive made an attempt but I think I may be wrong, before I bother post it, can I just check a few of my assumptions are correct?
- The surface reaction is perpendicular to the "rough plane".
- The friction force is directed directly up the "rough plane".
Im not too confident on those 2 assumptions and my initial attempt goes on those 2 being true :S
can someone please clarify?
thanks
This should be in the physics section but oh well
Draw the inclined plane with the mass anywhere on it...Consider the weight of the block(mg) and then consider the components of the weight...one acts parallel to the plane and the other acts perpendicularly to it. The normal reaction will be equal to the component perpendicular to the plane.
P will act in the same direction as the component of the weight parallel to the surface...
if [itex]F_1[/itex] is the component of the weight parallel to the plane and you know that that the frictional force([itex]F_R[/itex],which opposes motion down the plane) is equal to [itex]\mu*R[/itex] (R= the normal reaction) what condition should be fulfilled so that the block doesn't move?
I think this http://en.wikipedia.org/wiki/Inclined_plane" might help.
oo thanks :)
so to make the block not move, would I be right in saying all the forces would have to be in equilibrium? I am guessing by resolving in one direction (lets say right), and then in another perpendicular (lets say up)?
Trail_Builder said:
oo thanks :)
Well that is halfway correct...you see the resultant force perpendicular to the plane is Zero so that those forces are always in equilibrium...
now if all the forces down the plane("forward motion") is equal to all the forces resisting motion, then the block won't move...i.e. [itex]F_1+P=F_R[/itex]. Now consider what happens if the forces resisting motion is greater than the forces down the plane..i.e. [itex]F_R\geq F_1+P[/itex]
  • · Replies 20 ·
  • · Replies 19 ·
