Measuring acceleration of gravity
The discussion revolves around measuring the acceleration of gravity through a projectile motion experiment, where a body is projected upward and the time taken to pass two horizontal lines at different heights is analyzed.
  • Participants discuss the nature of the projectile's path, suggesting it is parabolic and questioning the presence of quadratic terms. They explore relationships among various events in the motion and consider different methods to derive the acceleration of gravity.
Some participants have shared their methods and insights, with one indicating they have solved the problem. Others are reflecting on the hints provided and considering alternative approaches without reaching a consensus on a single method.
There is mention of specific equations related to kinematics and the context of the problem being similar to a known physics textbook problem. The discussion includes varying levels of understanding and approaches to the problem.
tronter
[SOLVED] Measuring acceleration of gravity
The acceleration of gravity can be measured by projecting a body upward and measuring the time that it takes to pass two given points in both directions.
Show that if the time the body takes to pass the horizontal line [tex]A[/tex] in both directions is [tex]T_A[/tex], and the time to go by a second line [tex]B[/tex] in both directions [tex]T_B[/tex], then, assuming that the acceleration is constant, its magnitude is [tex]g = \frac{8h}{T_{A}^{2} - T_{B}^{2}}[/tex] where [tex]h[/tex] is the height of line [tex]B[/tex] above line [tex]A[/tex].
I am not sure how to approach this. I know that [tex]g = 9.8[/tex]. The path the body takes is a parabola. And [tex]a = \dot{v}[/tex].
Since the path is a parabola, I would expect there to be a quadratic term?
Draw a y-vs-t graph of the motion... a parabola.
Mark the two heights with [tex]y_B> y_A[/tex].
Note that there are four events.. label them sequentially as "1" (at A), "2" (at B), "3" (at B), "4" (at A).
Do you know any relationships among any of the quantities at those events?
By the way, this sounds like a Kleppner-Kolenkow problem.
yes it is. I already solved it.
Thanks
Great!
Did my hint help? Or did you come up with it yourself?
Or did you use a different approach?
[When solved, you can use the Thread Tools menu above to "Mark this thread as Solved".]
Yeah I just used [tex]y = y_0 + v_{y0}t - \frac{1}{2}gt^{2}[/tex] where we consider [tex]y_0 = y_A[/tex] and [tex]y_0 = y_B[/tex].
Then solve a quadratic, subtract, and rearrange.
I see. Good.
My method avoids solving a quadratic explicitly by using
the velocity and velocity-squared kinematic equations and some symmetry.
I have it now as I found the same problem in classical physics Thanks anyway
  • · Replies 16 ·
  • · Replies 33 ·
