Solving 5V 4E Graph Theory Problem
The discussion focuses on solving a graph theory problem involving the construction of three nonisomorphic, connected graphs with five vertices and four edges. The identified degree sequences are (1,1,1,1,4), (1,1,2,2,2), and (1,1,1,2,3). The argument presented confirms that all connected graphs with these degree sequences are isomorphic to the specified graphs, as the connectivity requirements dictate unique configurations for each degree set. The analysis concludes that the proposed reasoning sufficiently demonstrates the isomorphism of the graphs.
  • Understanding of graph theory concepts, specifically nonisomorphic graphs
  • Familiarity with vertex degree sequences and their implications
  • Knowledge of connected graphs and their properties
  • Ability to visualize and draw graphs for analysis
  • Study the properties of nonisomorphic graphs in graph theory
  • Learn about the significance of vertex degree sequences in graph connectivity
  • Explore the concept of graph isomorphism and its applications
  • Investigate methods for proving graph isomorphism through structural analysis
Students and professionals in mathematics, particularly those specializing in graph theory, as well as educators looking to enhance their understanding of graph connectivity and isomorphism.
dobry_den
Hi! I was given the following task:
(a) Exhibit three nonisomorphic, connected graphs with five vertices and four edges.
(b) Argue that every connected graph with five vertices and four edges is isomomorphic to one of the three in part (a).
It's not very difficult to draw the graphs:
http://i83.photobucket.com/albums/j315/dobry_den/graphs.jpg
but i can't think of how i would argue... Do you have any idea? Thanks in advance!
Maybe I've come up with something.. The sum of deg(v) has to be 8 (I have 4 edges, each is shared by two vertices). Moreover, there are 5 vertices, so the only combinations of degrees are: (1,1,1,1,4), (1,1,2,2,2) and (1,1,1,2,3).
(i) There's no other way how to connect (1,1,1,1,4) vertices to yield a nonisomorphic graph with the (1,1,1,1,4) graph from point (a). This is quite clear.
(ii) The same for a (1,1,2,2,2) graph.. This is a path and there's no other nonisomorphic connected graph that could be constructed from these vertices (eg. a graph consisting of a triangle and a path of length 1 has also vertices of degrees (1,1,2,2,2)..but it isn't connected).
(iii) To ensure that a (1,1,1,2,3) graph is connected, the vertices with degrees 3 and 2 must share an edge (otherwise, there would be no path from the former to the latter.. since the rest of the vertices are of deg=1.. and that would yield a graph that's not connected).. thus all graphs with the degree set (1,1,1,2,3) are isomorphic with the one on the picture.
Do you think this is sufficient?
