What Is the Period of SHM for a Rotated Cube Attached to a Spring?
  • Thread starter Thread starter brownniegyal
    Period Shm
The problem involves a cube attached to a spring, focusing on the period of simple harmonic motion (SHM) when the cube is rotated. The cube has specific mass and dimensions, and the spring constant is provided. The scenario begins with the spring at rest length and examines the effects of a small angular displacement.
  • Participants discuss the need for a visual representation to clarify the geometry involved. There are suggestions to relate the rotational motion to the spring's extension and to explore the relationship between the angle of rotation and the torque on the cube.
The discussion is ongoing, with some participants encouraging the original poster to engage more deeply with the problem. There is a recognition of the need for foundational understanding before tackling the current question, and suggestions for starting with simpler concepts have been made.
There is an indication that the original poster may not have attempted the problem sufficiently, which could affect the responses received. The discussion hints at the importance of understanding the underlying physics concepts, such as torque and moment of inertia, in relation to SHM.
brownniegyal
The 3.00 kg cube has edge lengths d = 6.30 cm and is mounted on an axle through its center. A spring (k = 950 N/m) connects the cube's upper corner to a rigid wall. Initially the spring is at its rest length. If the cube is rotated 3.00° and released, what is the period of the resulting SHM?
Please provide a solution rather than just an answer. I really appreciate any help:)
You are going to find that you won't get much of a response by just throwing questions into a template and posting them. You need to show that you've made at least some attempt at solving the problem on your own.
what if i don't get it at all :(
Then you should probably start with a simpler question where you are only partially lost. For this problem convert the rotational motion of the cube into a distance the spring is stretched (a picture would really help here - I'm not sure what the geometry is). Then determine an approximate linear relation between the angle of rotation and the torque on the cube which, together with knowing the moment of inertial of the cube, gives you a SHO for small angular displacements.
  • · Replies 20 ·
