How to Find the Mass Moment of Inertia for an L-Shaped Bar?
The discussion revolves around finding the mass moment of inertia for an L-shaped bar with specified dimensions and mass. The problem is situated within the context of rotational dynamics.
  • Exploratory, Assumption checking
  • Participants discuss the application of the parallel axis theorem and the need to determine the axis of rotation. There is mention of adding the moments of inertia of each leg of the bar and considerations regarding the formula for a thin rod.
The discussion is ongoing, with participants seeking clarification on the axis of rotation and the original problem statement. Some guidance has been offered regarding the use of the parallel axis theorem, but uncertainty remains about the specifics of the problem setup.
There is a noted lack of information regarding the axis of rotation, which is critical for solving the problem. One participant indicates they will provide a visual reference and the full problem statement in the future.
roldy
Find the mass moment of inertia of a L-shaped bar that has legs of 1.2 m long and total mass of bar is 20 kg.
I=1/12*m*L^2
I've tried attempting this problem but I just can't figure out how to apply mass moments to the parallel axis theorem.
Any help on this problem would be greatly appreciated. I need to figure this mass moment of inertia for a rotational dynamics problem I'm working on.
Add the moment of inertia of each "leg" together to get the total. Where's the axis of rotation?
The formula you gave is for a thin rod rotating about its center. You can use the parallel axis theorem to find the moment of inertia of a thin rod about any parallel axis.
still no luck
I do not know where the axis of rotation is. The problem states that a slender L-shaped bar is at rest in a vertical plane.
a bar rotating about it's end is 1/3mL^2
If you're not told the axis, how can you be expected to find the moment of inertia?
Please post the full problem exactly as given.
I'll scan in the picture tomorrow along with the question
  • · Replies 28 ·
  • · Replies 40 ·
