Can You Tune an Organ Pipe Without Altering Its Physical Construction?
  • Thread starter Thread starter celinemariah
    Frequency Pipe
Closing a hole in a pipe organ pipe that is designed to be closed at one end will lower the frequency of the note played by that pipe. To tune an organ pipe without altering its physical construction, several methods can be employed: adjusting stoppers at the end of stopped pipes, tuning collars at the top of pipes, tuning scrolls on the back of pipes, and modifying the resonating length of reed pipes. These techniques effectively change the pitch without physically altering the pipe itself.
  • Understanding of wave mechanics and frequency in acoustics
  • Familiarity with organ pipe construction and design
  • Knowledge of tuning methods for musical instruments
  • Basic principles of sound propagation in different temperatures
  • Research the effects of temperature on sound speed and frequency
  • Learn about tuning collars and their application in organ pipes
  • Explore the concept of partially stopped pipes, such as Chimney Flutes
  • Investigate the mechanics of reed pipes and their tuning methods
Musicians, organ builders, acoustics engineers, and anyone interested in the tuning and maintenance of pipe organs.
celinemariah
You are playing a pipe organ, with pipes that are designed to be closed at one end, when you notice that one of the notes sounds wrong. You soon discover that one of the pipes has a hole in the end that was supposed to be closed.
(a) After you patch up the hole, what will happen to the frequency of the note played by this pipe? Be as specific as possible.
(b) What else can you do to “tune” an organ pipe (i.e. change the frequency of the notes it plays) without altering the physical construction of the pipes? Indicate how you could increase the frequency of the note and also how you could decrease the frequency of the note.
My guess is that the frequency would increase with the hole closed up, but I'm not sure how to explain that. For the second question, I was thinking changing the room temperature would affect the speed, which in turn would affect the frequency, since the wavelength should remain the same.
A pipe closed at one end will produce waves that have a node at the closed end and an anti-node at the open end at its fundamental frequency. A pipe open at both ends has a node in the middle and an anti-node at the open ends.
Temperature is a way you can change the frequency without changing the pipe physically.
After the hole is closed, the frequency will be lowered. There are pipes in organs that are partially stopped (i.e. Chimney Flute) that have a "hole" in them.
Tuning methods: adjusting stoppers at the end of a stopped/partially stopped pipe, adjusting tuning collars attached to the top of the pipe, adjusting tuning scrolls on the back of a pipe (a scroll of metal cut but still attached to the rear of the top of a pipe), or adjusting the resonating length of a reed (reed pipes). All of these methods alter the pitch of a pipe without altering the actual pipe. Cone tuning is a tuning method that alters the actual pipe opening to change pitch.
  • · Replies 31 ·
9K
30K
17K
13K
