Total Stopping Distance at 80mph: How do you calculate it?
The total stopping distance for a car traveling at 80mph can be calculated using a quadratic equation derived from known stopping distances at lower speeds. The final formula established is d = 0.015714v² + 0.26286v + 0.60000, where d is the total stopping distance in meters and v is the speed in mph. The discussion emphasizes the distinction between braking distance and total stopping distance, with the latter including both braking and thinking distances. The analysis also highlights the non-linear relationship between speed and stopping distance, particularly at higher speeds.
  • Understanding of basic physics concepts such as kinetic energy and acceleration.
  • Familiarity with the equations of motion, particularly d = vt and KE = 0.5 * m * v².
  • Knowledge of the Highway Code of Great Britain regarding stopping distances.
  • Ability to perform basic statistical calculations, including averages and quadratic fitting.
  • Research the impact of aerodynamic drag on braking distances at high speeds.
  • Learn about the physics of braking systems, including ABS and their effect on deceleration.
  • Explore advanced statistical methods for fitting data to quadratic equations.
  • Investigate the relationship between reaction time and stopping distances in various driving conditions.
Automotive engineers, driving instructors, safety analysts, and anyone involved in vehicle performance and road safety assessments will benefit from this discussion.
i.am.lost
How do i work out the total stopping distance for a car at 80mph given that:
SPEED ... TOTAL STOPPING DISTANCE
20mph ... 12m
30mph ... 23m
40mph ... 36m
50mph ... 53m
60mph ... 73m
70mph ... 96m
Note that mph denotes miles per hour and m metres
The above figures are widely agreed on (as stated in the Highway Code of Great Britain), but it stops at 70mph and I must now work out the total stopping ditance at 80mph. Please give formula(e), as I am totally stumped.
I have tried the following methods, so please tell me if any are correct (d = total stopping distance):
1) Using the APPROXIMATION formula:
d = (v^2 / 20) + v
where v is velocity
2) Using the mathematical forecast formula which I want to avoid:
d (80mph as x in this formula ONLY) = a + bx
where a = AVERAGEy - (b * AVERAGEx)
and b = (SUM((x - AVERAGEx)*(y - AVERAGEy))) / (SUM((x - AVERAGEx)^2))
using the different speeds in mph as x and the known stopping distances as y
by SUM i mean sigma - so each value of x and y have to be subbed in
3) Finding the average increase between each known stopping sitance, and adding it to 70mph
4) Using t = (v - u) / a
where t is the time taken to stop
v is the final velocity (always 0 in this case)
u is the starting velocity
and a is the acceleration
Then using AVERAGEv = (v + u) / 2
where v is the final velocity (always 0 in this case)
and u is the starting velocity
And substituting the value of AVERAGEv and t in d = AVERAGEv * t
5) Using KE = 0.5 * m * v^2
where m is the mass of the vehicle
and v is the starting velocity (i think it should be starting)
And then substituting the value for kinetic energy in d = WD / f
where WD is the work done (equal to kinetic energy i think)
and f is the force applied to the brakes
The best ones i think are 4 and 5 (esp. 4), but the problem is i have so many unknowns, and when i try to work my way back to get acceleration, for example, i get different values for every known stopping distance. So now i am totally stumped.
Please help!
Addendum:
Hmmm... I've just had a flash of lightning but it might just be me. Using KE = 0.5 * m * v^2 it is obvious that doubling the velocity quadruples the kinetic energy. Hence, the braking distance is quadrupled.
This is proven in my figures as the stopping distance at 20mph is 12m, and at 40mph it is 36m (36 / 12 = 4).
It is also kind of disproven in the figures as the stopping distance at 60mph is not quadruple 30mph (73m and 23m, respectively).
Can anyone explain why this is the case for the 60/30mph? And is my theory right?
Final Word:
Woohoo! I have now finally solved it. The concept introduced in the addendum is actually correct, but it applies to the BRAKING distance not the total stopping distance - which includes the thinking distance. So by multiplying the braking distance at 40mph by 4, and then finding the trend for the thinking distance (which is simple - t(n) = 3n). By taking the sum of the braking and thinking distances, i have now arrived at the total stopping distance at 80mph!
Fitting the data in the table to a quadratic:
d = .015714 v^2 + .26286 v + .60000
or if v is in feet / second and d in feet
29.333 39.37
44.000 75.46
58.667 118.11
73.333 173.88
88.000 239.50
102.667 314.96
d = .023968 x^2 + .5878 x + 1.9740
1.9740 feet = probabaly due to ronding in the table.
.5878 is reaction time
braking decleration = 20.86 ft / sec^2 = .648g
My guess is that the table assumed braking deceleration of .65 g and .6 second reaction time and rounded to the nearest meter. Most of the simplified braking distance charts assume braking deceleration of .7g and vary on reaction time. In the real world, aerydynamic drag is a factor, so deceleration isn't a constant at higher speeds, and an integral would be required. Also some cars decelerate stop much better than .7g's especially with ABS.
Final Word:
Yes - the thinking time is assumed constant, so the thinking distance is linear.
  • · Replies 18 ·
