What is the Next Step in Calculating Wavelength for Singly Ionized Helium?
  • Thread starter Thread starter Ry122
    Wavelength
The discussion revolves around calculating the wavelength of the first line of the Balmer series for singly ionized helium, utilizing the energy level formula specific to this ion. Participants are exploring the relationship between energy levels and photon wavelength in the context of atomic physics.
  • Participants are attempting to understand the necessary steps to calculate the wavelength, questioning the relationship between energy and wavelength, and discussing the appropriate values for quantum numbers in the context of energy transitions.
The discussion is active, with participants clarifying the need to consider energy differences between multiple energy levels rather than a single energy value. Some guidance has been offered regarding the selection of quantum numbers for the calculation.
There is some confusion regarding the use of energy values and quantum numbers, as well as the specific transitions involved in the Balmer series for singly ionized helium. Participants are navigating these assumptions without a definitive resolution.
Ry122
The energy levels for singly ionised helium can be constructed from the formula:
E = 54.4/n^2 eV
Use this to calculate the wavelength of the first line of the balmer series for singly ionized helium
E=54.4 for the first line. Whats the next step?
Singly ionized helium is exactly like hydrogen, except with charge 2. So the ratios between lines are the same as the Balmer series for hydrogen.
can you tell me what equation i need to use?
You just gave it. Balmer lines are transitions between n>=3 and n=2. E=54.4eV isn't a line. It's the first energy level. Lines are the difference between energy levels.
Im supposed to be calculating the wavelength, but none of the variables in that equation represent wavelength.
What's the relation between energy of a photon and it's wavelength?
is it e = hc/wavelength ?
So what value do I use for n, 2?
Yes, for the first question. Though I don't know why you put a question mark after it. You don't use a value for n. You pick two values for n and find the energy difference. Pick the two values of n that make the difference largest. That's the first Balmer line.
if n isn't assigned a value, how can i find E?
You don't use ONLY ONE value for n.
You need to calculate the energy levels for two values of n.
The difference between these energy levels is what you are interested in.
  • Sticky
11K
