Electron Spin State and Values
The discussion revolves around the spin state of an electron represented by a vector and involves normalizing this vector, determining possible measurement outcomes for the z-component of spin, and calculating the expectation value of the spin operator.
  • Participants explore the normalization of the spin state vector and question the interpretation of measuring the z-component of spin. There are attempts to calculate the normalization constant and the expectation value, with some confusion regarding the correct application of operators and the resulting probabilities.
Some participants have provided guidance on normalization and the calculation of expectation values, while others express uncertainty about their results and seek clarification on their methods. Multiple interpretations of the measurement process are being explored, and there is no explicit consensus yet.
Participants mention varying results for the normalization constant and expectation values, indicating potential misunderstandings or miscalculations. There are references to specific values provided by a teacher, which may influence the ongoing discussion.
Rahmuss
[SOLVED] Electron Spin State and Values
An electron is in the spin state:
[tex]X = A\begin{pmatrix} 1-2i \\ 2 \end{pmatrix}[/tex]
(a) Determine the constant A by normalizing [tex]X[/tex]
(b) If you measured [tex]S_{z}[/tex] on this electron, what values could you get, and what is the probability of each? What is the expectation value of [tex]S_{z}[/tex]?
[tex]S_{z} = \frac{\hbar}{2}\begin{pmatrix}1 & 0 \\ 0 & -1 \end{pmatrix}[/tex]
[tex]\left\langle S_{z}\right\rangle = \left\langle X | S_{z}X\right\rangle[/tex]
Part a):
[tex]A^{2}\left[ |1-2i|^{2} + |2|^{2}\right] = 1 \Rightarrow[/tex]
[tex]A^{2}\left[ 1-4i+4+4\right] = 1 \Rightarrow[/tex]
[tex]A^{2}\left[ 9-4i\right] = 1 \Rightarrow[/tex]
[tex]A^{2} = \frac{1}{9-4i} \Rightarrow[/tex]
[tex]A = \sqrt{\frac{1}{9-4i}} \Rightarrow[/tex]
Part b):
For this part I'm a bit confused (thus the posting). I'm not sure what they mean when they talk about measuring [tex]S_{a}[/tex] on the electron. Are they just saying, if you measured the z-component of the spin of the electron? And if so would I have something like:
[tex]\frac{\hbar}{2}\begin{pmatrix} 1 & 0 \\ 0 & -1 \end{pmatrix} \begin{pmatrix}1-2i \\ 2 \end{pmatrix} \Rightarrow[/tex]
[tex]\frac{\hbar}{2}\begin{pmatrix} 1-2i \\ -2 \end{pmatrix}[/tex]
And where do I go from there? And as far as the probabilities I may be able to get that if I know the normalization constant. And I think I can get the expectation value from the normalization constant as well.
Any thoughts on normalizing this? I tried another way and got [tex]\frac{1}{3}[/tex] and another way and I got [tex]\frac{16\hbar - 2\hbar i}{18}[/tex]. And neither of those seem to work. I thought that 1/3 would work; but when I try to find the expectation value I get [tex]\frac{\hbar}{2} \frac{13}{3}[/tex].
Ok, I have from my teacher that [tex]A = \frac{1}{3}[/tex], and that [tex]\left\langle S_{x}\right\rangle = \frac{2\hbar}{9}[/tex].
I can normalize it and get [tex]A = \frac{1}{3}[/tex]; but I can't get the correct expectation value. Here is what I am doing:
[tex]\left\langle X | S_{x}X\right\rangle = A^{2}\frac{h}{2}[(1+2i), 2]\begin{pmatrix} 0 & 1 \\ 1 & 0 \end{pmatrix} \begin{pmatrix} (1-2i) \\ 2 \end{pmatrix} \Rightarrow[/tex]
[tex]A^{2}\frac{h}{2}[(1+2i), 2][2 + (1-2i)] \Rightarrow[/tex]
[tex]A^{2}\frac{h}{2}(2 + 4i + 4 + 1 + 4 + 2 -4i) = \frac{13\hbar }{18}[/tex]
So what am I doing wrong? I try including the the constants during the calculations and it comes out the same:
[tex]\left\langle X | S_{x}X\right\rangle = \begin{pmatrix}\frac{(1+2i)}{3} & \frac{2}{3} \end{pmatrix} \begin{pmatrix} 0 & \frac{h}{2} \\ \frac{h}{2} & 0 \end{pmatrix} \begin{pmatrix} (1-2i)/3 \\ 2/3 \end{pmatrix} \Rightarrow[/tex]
[tex]\frac{h}{2}\begin{pmatrix} \frac{(1+2i)}{3} & \frac{2}{3} \end{pmatrix} \begin{pmatrix} \frac{2}{3} & \frac{(1-2i)}{3} \end{pmatrix} \Rightarrow[/tex]
[tex]\frac{h}{2}\frac{(2 + 4i + 4 + 1 + 4 + 2 -4i)}{18} = \frac{13\hbar }{18}[/tex]
So, it still doesn't work. Any thoughts?
A matrix times a vector is a vector, so you want:
[tex]\left\langle X | S_{x}X\right\rangle = A^{2}\frac{\hbar}{2}[(1+2i), 2]\begin{pmatrix} 0 & 1 \\ 1 & 0 \end{pmatrix} \begin{pmatrix} (1-2i) \\ 2 \end{pmatrix} \Rightarrow[/tex]
[tex]A^{2}\frac{\hbar}{2}[(1+2i), 2][2, (1-2i)] \Rightarrow[/tex]
Now take the dot product of the two vectors:
[tex]A^{2}\frac{\hbar}{2}(2 + 4i + 2 - 4i) = \frac{2\hbar }{9}[/tex]
Ah... Ok. Great! Thanks 2Tesla. That helps a lot. That makes sense now. Ok, I can see why I wasn't getting it. Thanks again.
