AP Physics Free-Response Practice Question #2
The discussion focuses on solving a physics problem involving a large tank filled with saltwater, specifically calculating the force exerted on a drain plug, the speed of water exiting the hole, and the volume flow rate. The tank dimensions are 25m in height, with a plug located 5m from the bottom and a cross-sectional area of 4.0 x 10^-5 m^2. Key equations utilized include the continuity equation A1V1 = A2V2 and pressure calculations derived from the density of saltwater (1025 kg/m^3) and gravitational acceleration.
  • Understanding of fluid dynamics principles, specifically hydrostatic pressure.
  • Familiarity with the continuity equation in fluid mechanics.
  • Knowledge of basic physics concepts such as force, pressure, and flow rate.
  • Ability to perform unit conversions, particularly between mass and force.
  • Study hydrostatic pressure calculations in fluid mechanics.
  • Learn about the continuity equation and its applications in fluid flow.
  • Explore Bernoulli's principle and its relevance to fluid dynamics.
  • Investigate the relationship between flow rate and cross-sectional area in fluid systems.
Students studying AP Physics, educators teaching fluid dynamics, and anyone interested in practical applications of physics in real-world scenarios involving fluid flow.
xpeachpleasurex
A large tank, 25m in height and open at the top, is completely filled with saltwater (density 1025 kg/m^3). A small drain plug with a cross-sectional area of 4.0 X 10^-5 m^2 is located 5m from the bottom of the tank.
The plug breaks loose from the tank, and water flows from the drain.
(a) Calculate the force exerted by the water on the plug before the plug breaks free.
(b) Calculate the speed of the water as it leaves the hole in side of the tank.
(c) Calculate the volume flow rate of the water from the hole.
I'm not sure...I used the continuity equations A1V1 = A2V2
I calculated the volume of the water displaced and used the continuity equation and plugged in the numbers, but then I noticed that this was not the right way.
Start with part (a). How would you find the force on the plug?
You can change the density from being kg to N if you account for gravity:
gravity per volume = density * gravity. the units look like this:
N/m^3 = (kg/m^3) * (m/s^2)
From there you can multiply by the depth to get the pressure
N/m^2 = (N/m^3) * m
Now that you have the pressure in N/m^2, you can multiply by the surface area of the plug to get the force.
N = (N/m^2) * (m^2)Not exactly sure how to find speed, but I have a rough idea. It's probably wrong but it's wroth a shot...
<snip>
A little birdie suggested via report post that I delete this probably wrong response to avoid confusing the OP, who just wants help with his homework.
10K
