Determining length of highway deceleration ramp, with friction
This discussion focuses on calculating the length of a highway deceleration ramp required to stop an 80,000 lb truck traveling at 80 mph on a ramp inclined at 30 degrees with a friction coefficient of 1.5. The key equation used is (1/2) v^2 = g d sin(30) + u g d cos(30), which simplifies to d = (v^2) / [g(sin(30) + u cos(30))]. Substituting the values for velocity (v = 35.8 m/s), gravitational acceleration (g = 9.8 m/s²), and friction coefficient (u = 1.5) yields a ramp length of 72.7 meters. The discussion also explores the validity of using kinetic and potential energy equations in this context.
  • Understanding of basic physics concepts, specifically energy conservation.
  • Familiarity with trigonometric functions and their application in physics.
  • Knowledge of frictional forces and their calculations.
  • Ability to manipulate and solve algebraic equations.
  • Study the principles of energy conservation in mechanics.
  • Learn about the effects of friction on motion and stopping distances.
  • Explore the application of trigonometry in physics problems.
  • Investigate the dynamics of inclined planes and their real-world applications.
Students in physics or engineering courses, professionals involved in transportation safety design, and anyone interested in the mechanics of vehicle deceleration on inclined surfaces.
Satchmo
"At the base of a hill (blah blah) there is a ramp inclined with an angle of 30 degrees and has a surface with a coefficient of friction of 1.5. How long should this ramp be to be able to stop a 80,000lb truck traveling at 80 mph"
(delta)K + (delta)U = -fk * d (K is kinetic energy, U is potential energy, fk is friction force)
fk = u*n (u is frictional coefficient)
set Ki. = Uf + fk*d (having fk be positive, since you'd be subracting a negative anyway, right?) Ki = initial K.E., Uf = final P.E.)
(1/2) m v^2 = m g h + u n d (u is frict. coefficient, n is normal force, d is distance or hypotenuse of triangle, h is height.)
for the normal force I got n = m g cos(30)
and h = d sin(30)
{both of the above just using trig}
so (1/2) m v^2 = m g d sin(30) + u m g cos(30) d
m's cancel out
solve for d
plugging in v = 35.8 m/s (80 mph)
g = 9.8 m/s^2
u = 1.5
gives 72.7 meters. I don't have much faith in this answer. Can I do Ki. = Uf + fk*d for this problem?
Since it's giving you the coefficient of friction, I think that you'd want to use this equation to solve the problem:
[tex]2a(x-x_0)=v^2-v_0^2[/tex]
Solve for [tex]x-x_0[/tex]
Figure out [tex]a[/tex]
[tex]a=-g(\sin{\theta}+\mu \cos{\theta})[/tex]
Substitute:
[tex]x=\frac{v^2-v_0^2}{2a}=\frac{v_0^2}{2 g(\sin{\theta}+\mu \cos{\theta})}[/tex]
  • · Replies 29 ·
