How is momentum conserved in a two-dimensional collision?
  • Thread starter Thread starter Dinkydau444
    Momentum
The discussion focuses on the conservation of momentum in a two-dimensional collision involving two objects: a 4 kg object traveling at 10 m/s at a 30-degree angle above the negative x-axis, and a 6 kg object moving vertically along the y-axis. After the collision, the 4 kg object moves at 8 m/s at a 45-degree angle below the negative x-axis. Participants emphasize the importance of equating the x and y components of momentum before and after the collision to determine the velocity and direction of the second object.
  • Understanding of two-dimensional momentum conservation
  • Basic knowledge of vector components in physics
  • Familiarity with mass and velocity calculations
  • Ability to solve simultaneous equations
  • Study the principles of conservation of momentum in two dimensions
  • Learn how to resolve vectors into their x and y components
  • Explore collision types and their impact on momentum conservation
  • Practice solving problems involving two-dimensional collisions
Physics students, educators, and anyone interested in understanding the mechanics of collisions and momentum conservation in two-dimensional scenarios.
Dinkydau444
So this is going to be very hard to explain without a diagram, so i will try to include one as best as i can.
One object with mass 4 kg is traveling at 10 m/s. This object is in quadrant II of an x,y graph and is traveling toward the origin at 30 degrees above the negative x axis. The second object has mass 6 kg aand is traveling straight up the y axis. After the collision the first object (still with mass 4 kg) travels at 45 degrees below the negative x-axis at a speed of 8 m/s. The object with mass 6 kg is now traveling at some angle above the positive x-axis with some velocity. I have to find both the velocity and the direction this object is moving in
...x
..4kg...|
...O...|
...30...\...|
________\_|__________y
..45..4kg.O.|
...8.m/s./...|
This diagram shows how object 1 moves before (quadrant II) and after (Quadrant III)
the 30 and 45 are the angles of path the object travels in relation to the negative x axis
So object two with mass 6 kg and speed 8 m/s travels from below the x-axis straight up along the y-axis and impacts at the origin, then it travels diagonally right/upward into quadrant I
any help would be greatly appreciated
Momentum in two directions.
I think you have marked the axis wrongly. Interchange x and y letters.
Now take the x-component two momentums before collision and after collision and equate them. Similarly take the y-components of two momentums before collision and after collision and equate If needed use the conservation of energy.Solve the equations to get the velocity of the second body.
Yeah, i don't know why i labeled them incorrectly...sorry about that
and thank you very much, i think i understand now
18K
  • · Replies 21 ·
