Why Does Anything to the Power of 0 Equal 1?
  • Context: High School
  • Thread starter Thread starter Cummings
    Power Zero
The discussion centers around the mathematical reasoning behind why any non-zero number raised to the power of zero equals one. Participants explore various explanations, including algebraic manipulations, historical definitions, and recursive reasoning.
  • One participant notes the pattern in powers of two and questions the reasoning behind the rule that anything to the power of zero equals one.
  • Another participant suggests that algebra provides the answer, indicating that manipulating equations requires the assumption that x^0 = 1 for consistency.
  • A participant demonstrates that dividing a number by itself leads to the conclusion that a^0 = 1, using the example of 2 raised to various powers.
  • One contribution explains that the definition of zero exponents is derived from extending the rules of exponentiation, emphasizing that a^0 = a^1 / a for non-zero a.
  • Another participant highlights the recursive nature of exponentiation and points out that the definition fails for zero, leaving 0^0 undefined in general contexts.
  • A participant mentions that the transition from positive to zero exponents can be understood through division, reinforcing the idea that a^0 = 1.
  • One participant shares a teacher's explanation that a^1 / a^1 leads to a^0 = 1, supporting this with algebraic reasoning.
  • Several participants express appreciation for the clarity of explanations provided, indicating a positive reception to the discussion.
  • Related questions about the factorial of zero (0!) being equal to one are raised, with some participants providing reasoning based on recursive definitions of factorials.
Participants express various viewpoints and methods of reasoning regarding why a^0 = 1, but there is no consensus on a single explanation. The discussion remains open to multiple interpretations and approaches.
Some participants note that the reasoning for 0^0 being undefined is context-dependent and often requires explicit definitions in mathematical expressions.
This discussion may be useful for students and educators in mathematics, particularly those interested in the properties of exponents and factorials.
Cummings
Now.
2^4 = 16
2^3 = 8
2^2 = 4
2^1 = 2
2^0 = 1
i can see how:
2^3 = 2*2*2
2^2 = 2*2
2^1 = 2
but why does anything to the power of 0 equal 1.
i only know the rule that enything ot the power of 0 = 1 but why is it like that. Tell me, mathmaticly why it is.
Mathematics news on Phys.org
That's a damn good question. I would like to predict that people will answer that algebra alone provides this answer, rather than anything "logical". In the sense that if manipulating an equation that's large and has this X to the power of 0 in it, when manipulated the answer is only correct if we assume x^0 = 1
Let's see if I'm close!
23 / 23 =(2*2*2)/(2*2*2) =1
2a / 2b = 2a-b
got it?
now
23 / 23 =(2*2*2)/(2*2*2)= 23-3 = 20 = 1
in general
ab / ab
= (a*a*a*...*a) / (a*a*a*...*a)
[there are b a's in both the numerator and denominator]
=1
got it ?
ab / ab = ab-b = 1
therefore
20 = 1
30 = 1
40 = 1
a0 = 1
where b is an interger, a is a real number
Like much of arithmetic, the meaning of a zero exponent (and negative, fractional, and irrational exponents) is chosen because it forms an extension of previous mathematics that obeys most of the original rules.
Historically and logically, arithmetic starts with only the positive whole numbers and the increment operation, and everything beyond that is just layers of extensions.
The relevant case here is that exponentiation is first recursively defined for positive integral exponents by:
a1 = a
a * an = an+1
So the natural (ha ha!) thing to do is to flip the recursive step around and go backwards:
an = an+1 / a
and for a [x=] 0, this provides us with the definition for nonpositive integral exponents. In particular, for nonzero a:
a0 = a1 / a = a / a = 1
This isn't the only way, nor the only motivation, to arrive at nonpositive integral exponents. For instance, KL Kam gave reasoning based on using exponent arithmetic to extend the definition.
And this discussion wouldn't be complete without touching on 00. Notice that the above recursive definition fails when a is zero, because we can't divide by zero! KL Kam's fails for the same reason. Mathematically, 00 is left undefined because there isn't a value you can choose which will work with all common manipulations where that may arise. If a value is assigned to it at all, it is context defined and is often explicitly stated... most commonly because it can simplify notation when you write a polynomial like:
a + bx + cx2
as
ax0 + bx1 + cx2
(Yes, I know it doesn't simplify this notation, but this rewriting is useful for more complicated expressions, like Taylor series)
So because you're using x0 as a marker for the constant term it makes sense to define x0:=1 for x=0.
Just look at the list you gave:
2^4 = 16
2^3 = 8
2^2 = 4
2^1 = 2
To go from 2^4 to 2^3 you have to divide by 2: 16/2= 8.
To go from 2^3 to 2^4 you have to divide by 2: 8/2= 4.
To go from 2^2 to 2^1 you have to divide by 2: 4/2= 2.
To go from 2^1 to 2^0 what do YOU think you should do?
(Hint: 2/2= 1)
That also why 2^(-1)= 1/2 and 2^(-2)= (1/2)/2= 1/4, etc.
Yes...specialist math teacher told me that it works by
a^1 / a^1
A^1-1
a^0
and so as a^1 / a^1 = 1
a^0 = 1
and in the other ways you showed me..
KL - Brilliantly said. You answers a question I'd bet most people wouldn't never know because it's overlooked. And you did it perfectly! Well done!
On a related note, is there a reason 0! = 1?
I've only heard one explanation for that, but it was not algebraic.
Here is an explanation that I've heard.
4! = 4*3!
3! = 3*2!
2! = 2*1!
1! = 1*0!
If we work backward, we get
3! = 4!/4
2! = 3!/3
1! = 2!/2
0! = 1!/1 = 1
Thanks. Yeah, I think lots of people overlook it but I'm sure there are lots of members here who can answer this question.
  • · Replies 48 ·
  • · Replies 17 ·
  • · Replies 40 ·
  • · Replies 16 ·
  • · Replies 66 ·
