What Happens to Gas in Free Expansion?
  • Context: Undergrad
  • Thread starter Thread starter yashar_g
    Gas
The discussion revolves around the behavior of gas during free expansion into a vacuum, particularly focusing on the effects of temperature and pressure changes. Participants explore theoretical implications, experimental contexts, and the distinctions between ideal and real gases.
  • Some participants suggest that adiabatic expansion occurs when gas enters a vacuum, drawing parallels to scenarios like fire extinguishers.
  • One participant posits that a gas released into space would retain its temperature due to the absence of surrounding particles to absorb kinetic energy, raising questions about heat loss mechanisms.
  • Another participant counters that real gases experience cooling during expansion due to intermolecular forces that require energy to overcome, leading to a loss of kinetic energy.
  • It is noted that while ideal gases do not cool during free expansion, real gases do experience temperature changes, referencing the Joule-Thomson effect.
  • Participants discuss the implications of the ideal gas law and the conditions under which temperature changes occur during adiabatic processes.
  • Clarifications are made regarding the definition of free expansion and its distinction from other types of gas expansion, emphasizing the lack of work done on surroundings in free expansion.
Participants express differing views on whether a gas retains its temperature during free expansion, with some asserting that ideal gases do not cool while others argue that real gases do. The discussion remains unresolved, with multiple competing perspectives on the behavior of gases in this context.
Participants highlight the complexity of real versus ideal gas behavior, the role of intermolecular forces, and the conditions necessary for temperature changes during expansion. There is also mention of the limitations of the ideal gas law in certain scenarios.
yashar_g
what would happen to gas in...
Hi there,
I'm working on some experiments regarding to gases. I want to know what'd happen to gas which is uneder high temprature and high pressure when it enteres into vacuum.
it would be very kind of you to answer me in detail.
Many thanks, Yashar.
Science news on Phys.org
First thing that springs to mind is adiabatic expansion (comparable to what happens in a fire extinguisher)... not entirely sure though.
Hi there,
I'm working on some experiments regarding to gases. I want to know what'd happen to gas which is uneder high temprature and high pressure when it enteres into space.
is it loose temp.? (adiabatic?)
(Please don't multi-post the same thing.)
If it's a real gas, it will naturally expand and cool down in the process. If it does not radiate heat, the process should be adiabatic. You have to find the adiabatic law for real gases. Van der Waals' eqn of state may be a good approximation.
As I read your question and the reply I thought of something very interesting. If the hot gas is released into space, we would naturally think that the gas should cool down. However, heat is proportional to the kinetic energy of the gas molecules and since there is no surrounding particles to which the gas molecules can loose their kinetic energy, I would think that it would retain it's temperature. Afterall the only way in which anything can loose heat is by either giving it's kinetic energy to surrounding particles or emmiting it through electromagnetic waves. I don't believe that the gas would start emmiting waves as it is released into space, would it?
Pressure and temperature are inversely proportional. In vacuum pressure roughly = 0. Gases expand to occupy space. You can work out the rest...
Edit: I think what I wrote is bollocks (haven't slept for about 48 hours). So here's a gas law to cover my arse.
Pressure * volume = number of molecules * gas constant * temperature.
For an ideal gas in isolation, your argument is quite correct. However, there are various intermolecular forces in a real gas, which are feeble but attractive when the distances between molecules become large. In order to overcome these forces while expanding, the molecules have to lose a part of their KE, and the gas cools down in the process.
About the loss by EM radiation, that is also bound to happen. If two molecules collide, an electron may be pushed to a higher energy state, and it'll come to the ground state subsequently by emitting a photon.
The a/V^2 term in van der Waals’ eqn of state represents the attractive force, which reduces the observed pressure of a real gas, as compared to an ideal gas.
An ideal gas would not cool down while expanding in space, but any real gas would.
Pardon, your **** is still showing...it's not number of molecules, but number of moles.
That isn't correct, Shooting Star (though the reasoning for what actually happens is correct). An ideal gas undergoing adiabatic expansion cools down, as the ideal gas equations predict: http://en.wikipedia.org/wiki/Ideal_gas_law
Adiabatic cooling occurs when the pressure of a substance is decreased as it does work on its surroundings...
Such temperature changes can be quantified using the ideal gas law...
Russ,
An ideal gas expanding in space has no reason to cool down. It does not have any intermolecular force to overcome, nor any work to do by pressing on any outside wall. The average KE per molecule stays constant, since there is no way it can lose heat. (I am, of course, not considering heat loss by radiation, which will happen in a real gas.)
Perhaps I made a mistake by writing the phrase "gas in isolation". I was replyiing to Nerd's comment: "If the hot gas is released into space, we would naturally think that the gas should cool down."
Some further clarification from
http://en.wikipedia.org/wiki/Adiabatic_free_expansion:
Adiabatic free expansion is an irreversible process in which a gas expands without constraint, and during which no heat is exchanged. An example of the process is the release of a gas into a vacuum.
Real gases experience a temperature change (see Joule-Thomson effect) during free expansion. For an ideal gas, the temperature doesn't change, and the conditions before and after adiabatic free expansion satisfy piVi = pfVf, where p is the pressure, V is the volume, and i and f refer to the initial and final states.
I stand corrected. I didn't think that the "without constraint" part was critical, but I guess it is. If you expand a gas through a nozzle in the atmosphere, the atmosphere will absorb some of the energy of the expansion. In free expansion, the gas will literally expand forever. I'm still not 100% clear on this, though, since the page on the ideal gas law includes adiabatic (but not necessarily free) expansion and a temperature change calculation. I guess with free expansion, though, the volume goes to infinity and the pressure to zero.
  • · Replies 69 ·
  • · Replies 20 ·
