Thread Closed
Drop in Concentration as reaction progresses
Share Thread Thread Tools
Dec9-07, 08:20 AM   #1
I am currently doing an investigation into the reaction between different acids and magnesium metal. I want to try and show that by using a large volume of acid the concentration drop as the reaction progresses is significantly reduced. Is there any way of doing this?
2. Relevant equations
Mg (s) + 2 HCl (aq) --> H2 (g) + MgCl2 (aq)
Mg (s) + 2 H+ (aq) --> H2 (g) + Mg+2 (aq)
3. The attempt at a solution
Well I thought that by working out the moles of H+ ions present at the beginning of the reaction and at the end of the reaction may help. Other than that, I would just like to be pointed in the right direction.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Dec10-07, 02:35 PM   #2
Other Sciences 2012
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
You could remove an aliquot of solution at several intervals and titrate the acid. Plot the concentration of acid vs time for your result.
The results might surprise you, though...
Dec10-07, 03:14 PM   #3
well, so far I have found out the number of moles of HCL in 100cm3 of acid and then found the number of moles of H+ ions. I then found the percentage drop.
Dec10-07, 03:50 PM   #4
Other Sciences 2012
Recognitions:
What did you notice about the reaction rate?
Dec11-07, 06:03 AM   #5
well, I worked out that the maximum drop in concentration theoretically was 5.20% which for a concentration of 0.8 M is not significant.
Dec11-07, 01:17 PM   #6
Other Sciences 2012
Recognitions:
Thats what I thought would happen. Also, the metal surface area is shrinking during the reaction. This will cause the greatest change in rate of reaction.
Thread Closed
Thread Tools
Similar Threads for: Drop in Concentration as reaction progresses
Thread Forum Replies
is there a reaction called nucleus reaction??? High Energy, Nuclear, Particle Physics 6
If a reaction is not spontaneous is there any of making that reaction occur? Chemistry 6
nuclear reaction or chemical reaction Introductory Physics Homework 3
Bernoulli's Pressure Drop Segregated from Friction Pressure Drop General Physics 7
Reaction of Mg with acids (molat enthalpy and rate of reaction) Biology, Chemistry & Other Homework 1
