Entropy vs Temp graphfind Volume?
  • Thread starter Thread starter Roger Wilco
    Entropy Volume
The discussion revolves around finding the volume V_2 using a temperature vs. entropy graph. The original poster expresses confusion regarding the relationship between heat transfer, work done, and the variables involved, such as temperature and volume.
  • Participants discuss the first law of thermodynamics and the implications of the area under the curve in the context of the problem. There are questions about how to relate the work done in the cycle to the unknown volume V_2 and the significance of the isothermal process.
Some participants have offered guidance on using the first law and the relationship between heat transfer and work. There is an ongoing exploration of how to apply the given information, including the known initial volume and the conditions of the process, to find V_2.
There is a mention of missing information from the instructor regarding the initial volume at point 1, which is noted to be V_1 = 0.2 m². The discussion also highlights the challenge of relating the work done to the final volume without complete data.
Roger Wilco
Entropy vs Temp graph..find Volume??
I need to find V_2 by usinf the Temp vs. Entropy graph attached.
It says as a hint to use part b in which I found [tex]Q_{23}=0[/tex] by finding the area
under the curve (where ds=0).
Since Q=0 I know [tex]\Delta E_{int}=-W=nC_v\Delta T[/tex] but I am completely stumped! I know delta T, I know n, R...but I don't know any Vs or pressures.
Where do I start?!
I need some hints!
Thanks,
RW
I'm dyin' over here! Any ideas..i've been looking at this one since yesterday?!
Damn...
Where do I start?!I need some hints!
Try the first law:
[tex]dQ = TdS = dU + PdV[/tex]
What is the area inside the path? (ie the sum of the areas under each path)? What does that represent?
What is the work done in that cycle? How is that work related to V2?AM
Andrew Mason said:
Try the first law:
AM
The area inside the triangle abc= the total Q of the system right? I know that is cyclical so Delta E total is 0...So total W=total Q, but I am still having trouble relating this to Volume of 2?
RW
So it seems that my instructor left out the fact that at point 1, V_1=.2m^2.
And I am supposed to used the fact that [itex]dS=\frac{\delta Q}{T}[/itex] to find V_2. I know that 1-->2 is an isotherm, but I do not see how that would help. I that along the isotherm, [itex]W=nRT\ln\frac{V_f}{V_i}[/itex] but I don't see hpw that helps either? It isn't like I can solve for V_f if I know V_i and W is it?
RW
Yes. What is [itex]\Delta U[/itex] if there is no temperature change? What, then, is the relationship between [itex]\Delta Q \text{ and } W[/itex]?.
Why not?
You know everything except Vf once you work out the relationship between W and Q.
AM
