Help with determining Angle of Rotation for a Conic, please.
  • Context: Graduate
  • Thread starter Thread starter popsquare
    Angle Rotation
The discussion focuses on determining the angle of rotation for a conic section to eliminate the xy-term using the formula cot 2(theta) = (A - C) / B. The specific conic equation provided is 153x² - 192xy + 97y² - 30x - 40y - 200 = 0, with parameters A = 153, B = -192, and C = 97. The calculated angle of rotation yields -37 degrees, which is adjusted to 53 degrees for the other axis of the ellipse, satisfying the requirement for a counter-clockwise rotation within the range of 0 < theta < 90 degrees.
  • Understanding of conic sections and their equations
  • Familiarity with trigonometric functions, specifically cotangent and arctangent
  • Knowledge of angle rotation concepts in geometry
  • Ability to manipulate algebraic expressions and solve equations
  • Study the derivation of the angle of rotation for conic sections using the formula cot 2(theta) = (A - C) / B
  • Explore the properties of conic sections, particularly ellipses and their axes
  • Learn about the transformation of conic equations and how to eliminate cross-product terms
  • Investigate the implications of negative angles in geometric transformations and their interpretations
Mathematicians, geometry students, and anyone involved in analytical geometry or conic section analysis will benefit from this discussion.
popsquare
I am looking for the angle needed to rotate the conic to eliminate the xy-term
but the angle I find is negative and I need the counter-clockwise angle of rotation to satisfy 0 < theta < 90 degrees. Where am I going wrong? Or what else do I need to know? Thank you for your help.
I have this equation of a conic and I am supposed to find only the angle of rotation with this formula:
cot 2(theta) = A - C / B
The equation I am using is this:
153x^2 - 192 xy + 97y^2 - 30x -40y - 200 = 0​
I then solve for theta plugging these A = 153 , B = -192 , C = 97 into
I get this equation: cot 2(theta) = -56/192
Let theta = 2*theta
Then :
cot theta = -56/192
I take the inverse tangent to find 2*theta and then solve for theta like this:
arctan ( 192/-56) = -73.7398 degrees
Remember I let theta = 2*theta
-73.7398 = 2*theta
theta = -37 degrees.
Is there a way for -37 degrees to satisfy the original question?
If one axis of the ellipse is at -37 degrees then the other axis, at right angles to that, is 90- 37= 53 degrees.
i get it, thank you very much.
  • · Replies 0 ·
  • · Replies 30 ·
