Compact, connected, closed sets
The discussion revolves around properties of sets in topology, specifically focusing on compactness, connectedness, and closed sets. The original poster presents three statements regarding these properties and seeks assistance in proving them.
  • Participants suggest that the original poster should clarify definitions and assumptions related to compactness and connectedness. There is a discussion about the necessity of continuity for the function f in the context of the problems presented.
Some participants have provided feedback on the original poster's attempts, indicating that the responses may not fully address the questions posed. There is an ongoing exploration of the definitions and implications of the properties in question, with suggestions for deeper analysis.
Participants note that the original poster needs to show more work and clarify the notation used, particularly regarding the preimage of sets. There is also a mention of the need to consider the continuity of the function f when discussing the properties of the sets.
deanslist1411
1. If set A is compact, show that f(A) is compact. Is the converse true?
2. If set A is connected, show that f(A) is connected. Is the converse true?
3. If set B is closed, show that B inverse is closed.
Any help with any or all of these three would be greatly appreciated.
Stumped!
Welcome to the forums.
Note that, for homework questions, you need to show some work before we can help you. For example, a good way to begin would be to state the definitions of compact, closed,.. and all the other terms you are using here.
If you're trying to prove these for arbitrary functions, good luck. I imagine that the problem stated that f is continuous.
Also, by "B inverse" you probably meant "f-1(B)", i.e. the preimage (or inverse image) of B under f.
So for future reference, it would be good if, in addition to showing your work and thoughts, you posted the problems correctly!
Sorry, here goes.
Ans. f:M to N is continuous and A subset M is compact. Then f(A) is compact.
The converse is not necessarilly true. For Ex: F(x)=0 for every x in R(real #'s) and
k={0}. Then f^-1(k)=R is not compact.
Ans. f:M to N is continuous and A subset M is connected. Then f(A) is connected.
The converse is not necessarilly true. For Ex: F(x)=x^2 and k=1.
Then f^-1(k)={-1,1} which is not connected.
Ans. f is continuous on B if f is continuous on every x sub 0 element B.
a. f is continuous on B
b. for every x sub n to x sub 0 in A. f(x sub n) approaches f(x sub 0)
c. for any u open in N, f^-1(u) is open in M
d. for any F closed in N, f^-1(F) is closed in M.
I hope this is better. If anyone can add to this I would be greatfull.
Your answers for (1) and (2) are essentially just rewording the question. I'm not sure what the answer to three is supposed to be.
To start 1, write down the definition of compact, then suppose f(A) is not compact and see what you can find
You just reposted the question? Seems somewhat unnecessary...
