How to measure electrical frequency?
The discussion focuses on measuring electrical frequency and converting it to voltage using the LM2917 chip from National Semiconductor. It emphasizes the need for electronic frequency, which varies over time, to achieve accurate conversions. Various transducers, including magnetic pickups, are mentioned as effective tools for obtaining electronic frequencies from mechanical sources. The conversation also touches on the use of Schmitt triggers in the design process, although there is some debate regarding their effectiveness in sensing frequency.
  • Understanding of frequency-to-voltage conversion using LM2917
  • Knowledge of transducers, specifically magnetic pickups
  • Familiarity with Schmitt triggers and their applications
  • Basic concepts of electrical and mechanical frequency
  • Research the specifications and applications of the LM2917 chip
  • Explore different types of transducers for frequency conversion
  • Learn about the functionality and design considerations of Schmitt triggers
  • Investigate methods for converting electrical frequency to mechanical frequency (RPM)
Electrical engineers, automation professionals, and anyone involved in frequency measurement and conversion in electronic systems.
killjoy_scofiel
in f to V converter, input is frequencies . Is that electrical or Mechanical frequency?
To convert a frequency to a voltage, you need an electronic frequency (voltage varying in time).
One can use different types of transducers to get an electronic frequency from a mechanical one.
National makes a chip, LM2917, just for this application. Check out http://www.national.com/mpf/LM/LM2917.html" where you can see the transducer (magnetic pick up).
sensor transduces electrical frequencies?
how to convert this frequency to mechanical frequency(RPM),,,
i ve seen a design before, they use scmitt's trigger before f to V converter
generator--->trafo---->scmitt's---->LM2917---->PLC---->inTouchwonderware
i think schmitts don't sense the frequency...(no magnetic pick up)?
LM2917 only detect positive peak of sinusoidal wave?
http://www.imagehosting.com/out.php/i1447796_all.jpg
  • · Replies 20 ·
  • · Replies 0 ·
  • · Replies 17 ·
  • · Replies 20 ·
  • · Replies 27 ·
