Simple Ladder leading against a vertical wall become complicated.
  • Thread starter Thread starter dr3vil704
    Vertical Wall
The problem involves a uniform ladder of length L and weight w leaning against a vertical wall, with a focus on determining the smallest angle the ladder can make with the floor without slipping, given a coefficient of static friction.
  • Mixed
  • Participants discuss the setup of torque equations and the placement of pivot points to analyze forces acting on the ladder. There are questions about the assumptions made regarding friction and normal forces, as well as the relationship between these forces and the angle of the ladder.
Some participants have offered guidance on setting up equations for torque and force balance, while others are exploring the implications of their assumptions and calculations. There is an ongoing examination of the relationships between the forces involved, but no consensus has been reached on the correct approach.
Participants are working under the constraint of needing to find a numeric answer for the angle, with specific values for the coefficient of friction provided. There is also a mention of the requirement for equilibrium conditions in the analysis.
dr3vil704
A uniform ladder of length L and weight w is leaning against a vertical wall. The coefficient of static friction between the ladder and the floor is the same as that between the ladder and the wall. If this coefficient of static friction is μs = 0.500, determine the smallest angle the ladder can make with the floor without slipping.
I believe the set up of the problem is:
(1/2 X mg x Cos[tex]\theta[/tex] = ( N x L Sin[tex]\theta[/tex] ) +( Ff X Cos[tex]\theta[/tex] )
(Here Maybe the problem number)
I bring Ff X cos[tex]\theta[/tex] to the other side, and factor out the mg and divived the Sin. to get Tan[tex]\theta[/tex] by it self.
So the result is:
tan[tex]\theta[/tex]= (1/2 X L X mg - [tex]\mu[/tex]mg) / (mg X L)
Tan[tex]\theta[/tex] = (1/2 L - [tex]\mu[/tex]) / L
Okay, then the problem is that I'm suppose to get a numeric answer, to [tex]\theta[/tex] which is 36.8 degree.
If my attempt was on the right track, then How could i find the Numeric value of this if I only know what [tex]\mu[/tex] is?
I'm not sure if you did this, but you are using torque so you should set up the pivot point at either the floor or the wall to cancel out one of the Friction forces so you are left with only one F and mg. Then you make them equal (Tcw = Tccw).
Several problems: (1) Your torque equation should have an L in every term, which then cancels; (2) It looks like you assumed that friction equals [itex]\mu mg[/itex], but mg is not the normal force. Also, I don't quite see how you went from your first equation to your final version.
In addition to the torque equation, take advantage of the other conditions for equilibrium.
yes, I did put the pivot point on the floor, which cancel out the normal and friction between floor and ladder. So the frictional force that is left is between the wall and floor. And my friction and normal is not incline so it just [tex]\mu[/tex]mg. The first equation is Tcw=Tccw
Don't forget the friction force from the wall.
Yes, but with errors.
Oh, I see the mistake now. I guess I forgot to put the distance with the force
So the equation should be
(1/2 X mg X L X Cos[tex]\theta[/tex]) = (N X Lsing[tex]\theta[/tex]) +(Ff X cos[tex]\theta[/tex]X L)
But I do no get why the Ff agaisnt the wall is not [tex]\mu[/tex]N
Who says it isn't?
For equilibrium we require force balance and torque balance.
For force balance Sigms Fx = 0 i.e f1 - N2 = 0 where f1 frictional force at floor and N2 is the normal reaction on the wall. Sigma Fy = 0 i.e. mg - N1 - f2 = 0.
For torque balance mg*L/2*cos(theta) = f2*cos(theta) + N2*sin(theta).Substitute the value of mg. Then (N1+ f2)*L/2*cos(theta) =f2*cos(theta) + N2*sin(theta). Since Coeff. of friction is 0.5, N1 = 2f1 and N2 = 2f2 or f1 = 2f2. Substituting these values in the torque balance equation and simplifying you get tan(theta) = 3/4 or theta = 36.8 degree.
  • · Replies 27 ·
  • · Replies 24 ·
