Integrate f from x=y to pi/2: Solution
  • Thread starter Thread starter jra_1574
    Integration
The discussion revolves around the integration of the function f = sin^3(x)cos(y) from x = y to x = π/2. Participants are exploring the implications of the variable of integration and the limits involved.
  • Mixed
  • Some participants attempt to clarify the integration limits and whether the integration is single or double. Others discuss the treatment of constants in the integration process, particularly regarding the variable y as a limit versus a constant.
The conversation is ongoing with various interpretations being explored. Some participants have provided insights into the integration process, while others are questioning the clarity of the original problem statement. There is no explicit consensus on the interpretation of the integration limits.
There is a noted ambiguity regarding the integration variable and limits, with some participants suggesting that the original poster's phrasing could lead to confusion about whether a double integral is implied.
jra_1574
f:=sin^3(x)cos(y)
Integrate f, from x=y...pi/2)
I can do it if the two letters were y... But i have no idea how to solve when they are combined..
That is:
[tex]\int_y^{\pi/2} sin^3(x)cos^3(y) dx[/tex]
Find the anti-derivative (there's a standard method for odd powers of sin or cos) and evaluate between [itex]\pi/2[/itex] and y. Of course, the answer will not be number but will depend on y.
Integrate f with respect to what? Is this a double integration, or a single integration? Please state the question exactly as it is given.
f:=sin^3(x)*cos(y);
Integrate f with respect to x... from y to Pi/2
In all fairness to jra_1574, I wouldn't say that the question was ambiguous at all. The variable of integration may not have been explicitly stated but the way it was written
"from x=y...Pi/2"
seemed fairly obvious to me, and is in fact the way that some CAS's denote a definite integral (the primary example in mind would be Maple).
As for the actual question jra_1574, the integration doesn't depend on y, and so it's a constant and by linearity can be pulled out of the integral.
"from x=y...Pi/2"
Agree with everything you say except for the last line! y is the lower limit of integration and cannot be "pulled out of the integral".
What if instead it was written as f=sin(x)^3cos(0) and was integrated from 0 to pi/2. Couldn't the cos(0) be pulled out of the integral? I'm not sure how this is supposed to be any different
"from x=y...Pi/2"
That may be true, but the fact that he said "I don't know what to do when there are two letters" implied that it could be a double integration. Besides, one should always state explicitly what one is doing.
What you mean is that y is a constant when integrating wrt x, and so cos(y) can be treated as a constant.
Since cos(y) is a constant (with respect to x) it can be "pulled out of the integral". That is different from saying y (which is also the lower limit of integration) can be "pulled out of the integral".
[tex]\int_y^{\pi/2} sin^3(x)cos(y)dx= cos(y)\int_y^{\pi/2} sin^3(x) dx[/tex]
I assumed that was what Kreizhn meant. Never mind then
Yeah, sorry, meant the cos(y). It was late and I figured it was pretty obvious what I meant
Edit: Hurrah for semantical trivialities. I know that I should've stated that better but come on HallsOfIvy, I would've imagined that you knew precisely what I was talking about and was nit-picking
Actually, I was taken aback by it because I had focused on the "y" as a limit of the integral rather than the "cos(y)" while you were doing the opposite!
Also I agree that that looks like "half" of a double integral!
How would i type that in maple?
f:=sin(x)^3*cos(y)?
or f:=sin^3(x)*cos(y)?
anyways i pulled the cos(y) out of the integral, then change sin^3(x) to sin(x)*(1-cos^2(x))... i think that led me to
sin(x)-cos^2(x)*sin(x)
so integrate sin(x)= cos(x) minus
integration of cos^2(x)*sin(x) = i am not sure but is this g and g'? or i have to choose one to be u and do the du/dx?
Don't forget that there's a [itex]\frac{1}{2}[/itex] in there as well.
[tex]sin^2(x) = \displaystyle\frac{1}{2} \left( 1-cos(2x) \right)[/tex]
then let [itex]u = cos(x)[/itex] so that [itex]du = - sin(x) dx[/itex] and proceed from there.
In maple, you could write either
f:=sin(x)^3*cos(y);
or if you actually wanted to be able to evaluate f and certain points
f:=(x,y) -> sin(x)^3*cos(y);
OK thanks so much for your help!
  • · Replies 19 ·
  • · Replies 40 ·
