Thread Closed
Find the Second Resonant length of an air column
Share Thread Thread Tools
Dec12-07, 07:56 PM   #1
Find the second resonant length of an air column that resonates with a sound of frequency 1.0 kHz at 15.0 degrees Celsius under each of the following conditions.
a) the air column is closed at both ends
b) the air column is open at both ends
2. Relevant equations
[tex]V_{s}[/tex] = 332 m/s + T(0.59 m/s [tex]\circ[/tex]C)
v = f[tex]\lambda[/tex] therefore [tex]\lambda[/tex] = [tex]\frac{v}{f}[/tex]
l = [tex]\frac{n \lambda}{2}[/tex] therefore [tex]\frac{2l}{n}[/tex] = [tex]\lambda[/tex]
n = 2 for the second resonant length of an air column
3. The attempt at a solution
332 m/s + 15(0.59 m/s)
= 340.85
[tex]\frac{340.85 m/s}{1000 Hz}[/tex]
= 34.09 cm
[tex]\lambda[/tex] = [tex]\frac{2(34.09}{2}[/tex]
= 34.09
The second Resonant length is 34.09 cm
I don't know how to calculate the difference between an air column open at both ends
and an air column closed at both ends. My textbook doesn't explain it clearly. I'm guessing that both types of columns have different answers but as it stands I got the same calculation for both types. Is there more to the equation that I'm missing or am I doing the whole calculation wrong.
Thanks
S
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Dec12-07, 11:06 PM   #2
Recognitions:
Homework Helper Homework Help
In open air column open ends will be antinodes. So the second resonant length = wavelength. In closed air column closed ends will be nodes. So the second resonant length is also equal to wavelength.
Dec13-07, 09:53 AM   #3
Does that mean that both questions have the same answer?
Dec13-07, 05:53 PM   #4
Recognitions:
Yes.
Thread Closed
Thread Tools
Similar Threads for: Find the Second Resonant length of an air column
Thread Forum Replies
Resonant length Introductory Physics Homework 2
Resonant length Introductory Physics Homework 1
Open end resonant length Introductory Physics Homework 1
resonant length and wavelength of sound? Introductory Physics Homework 0
