Precession: Deriation of formula
  • Context: Graduate
  • Thread starter Thread starter JolleJ
    Formula Precession
The discussion centers on the derivation of the formula for precession, specifically the equation \textbf{wp} = \frac{Q}{I*w}, and the relationship between angular momentum and torque. Participants explore the mathematical foundations and conceptual understanding of these principles, with a focus on applications such as the precession of a bicycle wheel.
  • One participant requests clarification on the derivation of the precession formula and its relation to angular momentum.
  • Another participant suggests a resource for understanding gyroscopic precession.
  • A participant expresses confusion about a specific equation and its components, questioning its validity and origin.
  • Some participants discuss the significance of infinitesimally small angles in the derivation process.
  • One participant critiques a linked derivation as being sloppy and indicates they will provide their own version.
  • Another participant shares a resource that aligns closely with their own understanding, indicating it saves them effort.
  • Participants discuss the need for a combination of different derivations to explain specific applications, such as a bicycle wheel.
  • One participant seeks feedback on their written derivation and questions the validity of their argument regarding small angles and angular momentum.
  • Another participant confirms the approximation of sine for small angles and provides additional reasoning related to arc length.
Participants express varying levels of understanding and agreement on the derivation process, with some indicating confusion and others providing clarifications. Multiple competing views and interpretations of the derivation remain present, and the discussion does not reach a consensus.
Some participants note limitations in the clarity of existing derivations and express uncertainty about specific mathematical steps and definitions. The discussion reflects a range of assumptions and interpretations regarding the concepts involved.
JolleJ
Please see this link first: http://en.wikipedia.org/wiki/Precession#Classical_.28Newtonian.29"
How do they get to the formula
[tex]\textbf{wp}[/tex] = [tex]\frac{Q}{I*w}[/tex]
I also note that I*w = L (angular momentum).
How do they get to that equation? I've thought and though, I just don't know how. I really hope that someone can give me a link to a deriation of it, or perhaps help me themselves.
Thanks in advance.
Try this: http://scienceworld.wolfram.com/physics/GyroscopicPrecession.html"
Wow! Thank you so much.
Just one thing though: In equation (4), the d0, what is that? Change in angle? And where does that equation (4) come from? Never seen it before? Why is that true? :s
I think I get it now actually. It is because the change as well as angle are inifitsmally small... :) Right? :D
Yes, that's it. And because the torque is perpendicular to the angular momentum.
Now that I looked it over more carefully, I'm not happy with that derivation that I linked. It seems a bit sloppy. I'll post my own version in a bit.
Oh thank you so much! :o It's deeply appreciated.
I was just about to post my own derivation, when I found this on hyperphysics (one of my favorite educational sites--I highly recommend it): http://hyperphysics.phy-astr.gsu.edu/hbase/top.html"
This is almost exactly what I would have written, so it saves me the trouble! If you have questions about this derivation, let me know.
Thank you once more. What I need is acutally a combination of the two. The first is good because it fits the precession of a bicycle wheel (which is what I need to explain), and the next is good because of the smart derivation.
I've tried to write it down, how I think I need it. But I'm not sure, if I did any errors... I would very much like if you could just quickly look it through?
Here's the link: http://peecee.dk/?id=85095" (danish upload site: Click "Download fil").
At the moment it hasn't got an illustration, I will make one however.
Thanks in advance, once again. :smile:
Oh, and a last question: Is this good argumentation:
If I call the angle v. Can I say this:
"It is obvious that
[tex]sin(v) = \frac{\Delta L}{L}[/tex]​
For infinitsimal small angles sin(v)=v, so that:
[tex]dv = \frac{dL}{L}[/tex]​
since the angle is small when delta L is small."
Thanks in advance.
It looks OK to me. Note that your "r" is the moment arm--I assume your bicycle wheel is oriented perpendicular to the vertical?
"It is obvious that
It is certainly true that for small angles [itex]\sin\theta \approx \theta[/itex], as long as the angle is in radians. But you can also argue directly that as [itex]\Delta L[/itex] becomes small it more closely approximates the arc length of a circle, thus [itex]\Delta L/L[/itex] becomes the radian measure of the angle.
Thank you once more! :) I think I get it now. :D
  • · Replies 35 ·
  • · Replies 33 ·
