Solve Calc-Based Kinetics Problem: Initial Velocity for Washington Monument
The problem involves determining the initial velocity required for an object to reach the top of the Washington Monument, which is approximately 550 feet high. The context is rooted in calculus-based physics, specifically focusing on kinematics and the effects of constant acceleration due to gravity.
  • The original poster attempts to understand the role of constants in the integration process of acceleration to find velocity and position functions. They question whether the constants derived from different integrations are the same or different.
  • Some participants clarify the integration steps and the significance of the constants, suggesting that the constants are indeed different and should be treated accordingly.
  • There is a discussion about the relationship between calculus and physics, with participants expressing a desire for a more integrated approach to teaching these subjects.
The discussion is active, with participants providing clarifications on the integration of acceleration and the implications for initial conditions. There is an exchange of ideas about the historical context of kinematic equations and their derivation, indicating a productive exploration of the topic.
Participants express varying levels of familiarity with calculus and physics, with some noting that their understanding of one subject has been enhanced by learning the other. There is a recognition of the historical development of these concepts and a desire for a more cohesive educational approach.
lLovePhysics
With what intial velocity must an object be thrown upward (from ground level) to reach the top of the Washington Monument (approx 550ft)?
Here's what I know:
s(0)=0
a(t)=-32ft/s^2
[tex]s(t_{max})=550\\<br /> s'(t_{max})=0[/tex]
Actually I got the correct answer but I don't understand something. How do you know whether the constants "C" given by the indefinite integrals are the same?
For example, when you integrate a(t)=s''(t) you get:
s'(t)=-32+C
When you integrate the velocity or s'(t) you get:
[tex]s(t)=-16t^2+Ct+C[/tex]
So are those C's the same or are they different? How do you know? When I treated them the same I got the correct answer, but when I didn't the answer turned out to be wrong.
Can someone please explain the "constants dilemma?" Thanks.
They are different. And s'(t)=-32t+C, you left out the t. You fix the constants by making sure that s(0)=0 and the max of s(t) is 550ft.
s'(t)=-32t+C [I corrected this line.]
Since you integrated the (constant) acceleration function, you now have the velocity function. The velocity at time t = 0 would be
v(0) = s'(0) = -32·0 + C = C ,
so the "arbitrary constant" becomes your initial velocity v(0). Now,
[tex]s(t) = -16t^2 + Ct + D[/tex] [it's a good idea to call the second arbitary constant something else]
The position function is now
s(t) = -16(t^2) + v(0)·t + D ,
which at time t = 0 becomes
s(0) = -16·(0^2) + v(0)·0 + D .
So the second arbitrary constant is D = s(0), the initial position. This is where the textbooks get the formulas for constant acceleration (a) kinematics
v(t) = v(0) + at ,
x(t) = x(0) + v(0)·t + (1/2)·a·(t^2) .
WOW That's so cool! Okay thanks guys. First time seeing things in both the calculus and physics perspectives. lol
I really wish the two were simply taught together, since they grew up together. A great deal of mathematical technique and theory for millenia, but particularly over the last four hundred years, was in aid of solving increasingly sophisticated problems in physics and engineering...
Yeah, me too. Unfortunately I learned physics before learning calculus, which I'm currently taking. I wish I had learned both together. I'm glad I took physics though, or else I wouldn't understand the physics-based calculus problems as much.
Also, I can't believe I never knew how to actually derive these formulas.. I guess I couldn't anyways since I did not know any calculus to begin with.
Actually, the constant acceleration kinematic equations were already known in medieval Europe. If you make a graph of a constant acceleration function and ask how the area under it increases as time on the graph advances, you get the velocity equation given above. If you do the same with that function, you get the position equation. (They were doing what we would now called "graphical integration".) Newton developed calculus in order to grapple with problems involving non-constant accelerations.
  • · Replies 17 ·
  • · Replies 17 ·
