| Thread Closed |
I made the following conjecture |
Share Thread | Thread Tools |
| Dec17-07, 01:24 PM | #1 |
Every prime number > 3 could be written as a sum of a prime number and a power of two.
p,q are primes, n is positive whole number ==> p = q + 2^n 5 = 3 + 2^1 7 = 5 + 2^1 = 3 + 2^2 11 = 7 + 2^2 13 = 5 + 2^3 17 = 13 + 2^2 19 = 3 + 2^4 23 = 7 + 2^4 29 = 13 + 2^4 31 = 23 + 2^3 37 = 29 + 2^3 87 = 23 + 2^6 101 = 37 + 2^6 1213 = 701 + 2^9 1217 = 1153 + 2^6 1223 = 967 + 2^8 seems that this is really truth, but fails for some primes (997, 6659 are some primes that this is not true) I wonder if there is some property which could be used to discriminate such primes |
| Dec17-07, 01:55 PM | #2 |
You can, however, write
997 = (-1051) + 2^(11) and 6659 = (-16 770 557) + 2^24 where both 1,051 and 16,770,557 are prime. |
| Dec17-07, 02:06 PM | #3 |
| Dec17-07, 02:35 PM | #4 |
Had a hunch that n might be s.t. 2^n > p.
Then it took just a little trial and error and a Mathematica system. Probably not too hard to write a program that does it automatically. |
| Dec17-07, 02:57 PM | #5 |
Actually, here is an ugly (but effective) one
Code:
CheckConjecture[n_] := Module[{},
If[!PrimeQ[n], Print[n, " is not prime"]; Return[]];
For[i = 0, i <= Sqrt[n], i++,
If[n - 2^i // PrimeQ,
Print[StringForm["`` = `` + 2^``", n, n - 2^i, i]]; Break[],
![]() (note, upper boundary is selected somewhat arbitrarily. I think it would be very odd if you happened to plug in a prime for which it even needs to get close). Here is the result for the first 100 prime numbers Code:
Composition[CheckConjecture, Prime] /@ Range[1, 100]; 3 = 2 + 2^0 5 = 3 + 2^1 7 = 5 + 2^1 11 = 7 + 2^2 13 = 11 + 2^1 17 = 13 + 2^2 19 = 17 + 2^1 23 = 19 + 2^2 29 = 13 + 2^4 31 = 29 + 2^1 37 = 29 + 2^3 41 = 37 + 2^2 43 = 41 + 2^1 47 = 43 + 2^2 53 = 37 + 2^4 59 = 43 + 2^4 61 = 59 + 2^1 67 = 59 + 2^3 71 = 67 + 2^2 73 = 71 + 2^1 79 = 71 + 2^3 83 = 79 + 2^2 89 = 73 + 2^4 97 = 89 + 2^3 101 = 97 + 2^2 103 = 101 + 2^1 107 = 103 + 2^2 109 = 107 + 2^1 113 = 109 + 2^2 131 = 127 + 2^2 137 = 73 + 2^6 139 = 137 + 2^1 149 = -107 + 2^8 151 = 149 + 2^1 157 = 149 + 2^3 163 = 131 + 2^5 167 = 163 + 2^2 173 = 157 + 2^4 179 = 163 + 2^4 181 = 179 + 2^1 191 = 127 + 2^6 193 = 191 + 2^1 197 = 193 + 2^2 199 = 197 + 2^1 211 = 179 + 2^5 223 = 191 + 2^5 227 = 223 + 2^2 229 = 227 + 2^1 233 = 229 + 2^2 239 = 223 + 2^4 241 = 239 + 2^1 251 = -5 + 2^8 257 = 241 + 2^4 263 = 199 + 2^6 269 = 13 + 2^8 271 = 269 + 2^1 277 = 269 + 2^3 281 = 277 + 2^2 283 = 281 + 2^1 293 = 277 + 2^4 307 = 179 + 2^7 311 = 307 + 2^2 313 = 311 + 2^1 317 = 313 + 2^2 331 = -181 + 2^9 347 = 331 + 2^4 349 = 347 + 2^1 353 = 349 + 2^2 359 = 103 + 2^8 367 = 359 + 2^3 373 = -139 + 2^9 379 = 347 + 2^5 383 = 379 + 2^2 389 = 373 + 2^4 397 = 389 + 2^3 401 = 397 + 2^2 409 = 401 + 2^3 419 = 163 + 2^8 421 = 419 + 2^1 431 = 367 + 2^6 433 = 431 + 2^1 439 = 431 + 2^3 443 = 439 + 2^2 449 = 433 + 2^4 457 = 449 + 2^3 461 = 457 + 2^2 463 = 461 + 2^1 467 = 463 + 2^2 479 = 463 + 2^4 487 = 479 + 2^3 491 = 487 + 2^2 499 = 491 + 2^3 503 = 499 + 2^2 509 = -3 + 2^9 521 = 457 + 2^6 523 = 521 + 2^1 541 = 509 + 2^5 Code:
9544791479 = 9544791463 + 2^4 22129347137 = 22129347133 + 2^2 4648194659 = 4648194643 + 2^4 11534533159 = 11400315431 + 2^27 20435808557 = 20435808493 + 2^6 11932479739 = 11932446971 + 2^15 14934903251 = 14934641107 + 2^18 21592521889 = 21592519841 + 2^11 20643758743 = 20643758741 + 2^1 17469583409 = 17468534833 + 2^20 3084406151 = 3017297287 + 2^26 7767771523 = 7767771521 + 2^1 In fact, if you have access to Mathematica yourself, you might find it interesting to plot the powers of two separately: Code:
PowerOfTwo[n_] :=
Module[{}, If[! PrimeQ[n], Print[n, " is not prime"]; Return[-1]];
If[n - 2^i // PrimeQ, Return[i], -1]]]
{Range[1, 5000], Composition[PowerOfTwo, Prime] /@ Range[1, 5000]} // Transpose // ListPlot
(Composition[PowerOfTwo, Prime] /@ Range[1, 10000]) // Tally // ListPlot
| Dec17-07, 03:04 PM | #6 |
| Dec17-07, 03:14 PM | #7 |
compuchip, could you write an algoritm that expresse a prime as a sum of the minor prime possible and powers of two?
in another words: given the prime 31 we have: 7 = 5 + 2^1 = 3 + 2^2 23 = 7 + 2^4 31 = 23 + 2^3 ==> ==> 31 = 3 + 2^2 + 2^3 + 2^4 my idea was: if a I prove that every single prime could be written as a sum of a prime and a power of 2 (and extract the exacly reason why some of then couldn't), maybe I could derive some properties of the distribution of primes in terms of the power of 2 series If you generate such list that I am asking for (a prime as the minor prime possible plus some powers of 2), perhaps some interesting pattern in the powers will shows up |
| Dec17-07, 04:02 PM | #8 |
The minor prime possible is always 3 (or 2, if you allow 2^0), since the difference between 3 and the prime (or any positive integer, for that matter) can be expressed (uniquely) as a sum of powers of two; think of its binary representation.
| Dec17-07, 04:07 PM | #9 |
Recognitions:
A065381 are those primes that cannot be represented in this way. A list of the first 1000 such primes is here:
http://www.research.att.com/~njas/sequences/b065381.txt See also A078687, the number of ways to represent each prime as p + 2^k. |
| Dec17-07, 04:19 PM | #10 |
Recognitions:
Up to 10 million there are 664,579 primes, of which 102,613 cannot be represented in this way. Up to 50 million there are 4,77,446 primes, of which 477,446 cannot be represented in this way.
| Dec17-07, 07:22 PM | #11 |
CRg. do you know who was the first to have the same insight?
I was speculating about goldbach's conjeture just for curiosity and this insight came to me, was very nice to see a possible pattern coming out! Will it be that anybody knows a proof for that? |
| Dec17-07, 07:38 PM | #12 |
Seems that the number of primes that cannot be represented in such way decrease comparatively with the total of primes
| Dec18-07, 11:59 AM | #13 |
Recognitions:
lim N(n)/pi(n) = 0. What does everyone think? I'm curious about the cardinality of A065381: is it finite? |
| Dec18-07, 01:59 PM | #14 |
I think that you did not see that I had open the thread, I'm saying that I have this insight of represent primes as a prime plus 2^n once when I was studying goldbach's conjeture. Could be not a big deal, but I had this "insight" and now I see that someone had the same insight, I just asked you about more information of that.
Nothing is proved by direct computation, as you know, in terms of infinity, or do you think that a massive data could prove that there are infinite primes in p + 2^n form? regards |
| Dec18-07, 02:04 PM | #15 |
Recognitions:
| Dec18-07, 02:10 PM | #16 |
I edited, read above, I mean that I have the insight... sorry, my english is not so good...
| Dec19-07, 01:21 PM | #17 |
Recognitions:
Call S the set of primes that can be represented in the form p + 2^k.
The twin prime conjecture (more generally, de Polignac's conjecture or the first Hardy-Littlewood conjecture) implies that S is infinite. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: I made the following conjecture
| Cells are made of molecules,molecules are made of atoms,atoms are made of energy.so.. | Biology | 9 | ||
| BKL Conjecture | Special & General Relativity | 0 | ||
| Name that conjecture | General Math | 4 | ||
| Proof of Golbach's conjecture and the twin prime conjecture | Linear & Abstract Algebra | 9 | ||
| My Conjecture | General Discussion | 0 | ||
