| Thread Closed |
Solving a first-order nonlinear differential equation. |
Share Thread | Thread Tools |
| Dec19-07, 02:43 AM | #1 |
[Differential equation at the end; All the intermediary stuff is the problem behind it.]
I was curious about finding the velocity function for a free-falling object using solely newton's equations. Using the force diagram, I've deduced that m-mass g-gravitational constant f_net - net force A - cross-sectional area v - velocity f_net = mg-1/4Av^2 ma = mg - (Av^2)/4 a=g-(Av^2)/4m v'=g-(Av^2)/4m and g, A and m are constants. In this case, I simplified by assuming A=1, m=1 so the equation becomes the nonlinear first-order differential equation v'=9.8-.25v^2. How do you... solve this kind of equation? |
| Dec19-07, 02:55 AM | #2 |
We might tidy up your problem as follows:
Set [tex]\epsilon^{2}=\frac{A}{4mg},w(t)=\epsilon{v}(t)[/tex] Multiplying your diff.eq with [itex]\epsilon[/itex], we get: [tex]\frac{dw}{dt}=\epsilon{g}(1-w^{2})[/tex] Agreed so far? |
| Dec19-07, 02:58 AM | #3 |
Latex was a bit grumpy, it should be okay now.. |
| Dec19-07, 05:21 AM | #4 |
Looks to me like an easily separable equation: get all "v"s on one side, all "t"s on the other and integrate.
| Dec19-07, 12:21 PM | #5 |
| Dec19-07, 12:29 PM | #6 |
Have you done separable diff. eqs yet?
| Dec19-07, 12:32 PM | #7 |
So I see how this might solve a problem that I *think* I was having earlier.
So, e-epsilon dw/(1-w^2) = eg dt Then the left side would be integrated in respect to initial and final "w", which then could be converted into v terms post-integration(or would be it better to do it pre-integration? I'm not immediately seeing how that would simplify things since the current form seems to be an immediately integrable form, I just need to look up the charts.), and the right side could be integrated in respect to initial and final t, and then velocity can be straightforwardly solved for algebraically? Is this a fruitful direction? (Where do I learn how to use LaTeX(Wrong capitalization sequence? baha) on the forums, by the way?) Ok. So I think I've found a definite way to solve it. w = ev dw = e dv dw/(1-w^2) = e dv/(1-e^2v^2) (So pre-integration conversion seems to be better). Looking at the table of integrals, it appears that the last form integrates to an inverse hyperbolic tangent which then the function v can be solved for. |
| Dec19-07, 12:35 PM | #8 |
| Dec19-07, 12:56 PM | #9 |
You should get, starting from rest: [tex]w(t)=Tanh(egt)[/tex], where a positive velocity means a downwards velocity, due to the sign choice you made at the start. Tanh is the hyperbolic tangent function. |
| Dec19-07, 01:34 PM | #10 |
Really?
So w(t) = tanh(egt)? Then ev(t) = tanh(egt) v(t) = tanh(egt)/e When I tried solving it by pre-converting w in terms of v before integrating, I ended up v(t) = tanh(e^2gt)/e. I'm thinking that I superfluously inserted an e somewhere, but I don't know where. if w = ev then dw/dt = e dv/dt (Right?) dw = e dv(right? Imagine another "Right?" to each step hereafter.) dw/(1-w^2) = e dv/(1-e^2v^2) ...(integrating).... = e tanh.... Hehe... nevermind... I forgot to multiply the e in front of the integral by the e in the denominator of the evaluated integral(Which cancels out all tanh^(-1)-external e's on the left side). So, yeah, pre-integration works as well as post-integration. Sweet. Even cooler; The graph ACTUALLY looks realistic! (I just realized another method to solve this problem could be done by using an energy approach. It seems like it wouldn't have to involve differential equations, either.) Anyways, thanks! This has been extremely informative! So... with differential equations like this, just basically restate the equation so that one side could be completely expressed as products and the other side as the derivative and.... divide and conquer. (Perhaps there's a quicker more "standard" way, but this seems to get the job done.) |
| Dec19-07, 01:46 PM | #11 |
Note that 1/e is the "steady-state" velocity as time goes to infinity.
Also: We ASSUMED that we let the object from rest, falling freely. But, we may ask: If we throw the stone upwards, how will that affect the motion? In this case, BOTH gravity and air resistance work against the motion, we will get a (trigonometric) tangent relationship between velocity and time, rather than a hyperbolic one. Try it out! (assume some initial velocity V>0) |
| Sep14-08, 09:08 AM | #12 |
All;
I have encountered a nonlinear first-order differential equation in my research. It appears rather simple yet I have been unable to solve it. Any clues/tips would be highly appreciated. First I state it in the original form: y'[x] - 1/y[x] = - Exp[-1/x] / x^2 Next I state it written in the form of an Abel equation, obtained by setting q[x]=1/y[x]: q'[x] + q[x]^3 = q[x]^2 * Exp[-1/x] / x^2 Thanks in advance for any thoughts! Pete |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Solving a first-order nonlinear differential equation.
| Solution to 1st order nonlinear differential equation | Differential Equations | 14 | ||
| how to solve this 2nd order nonlinear differential equation | Differential Equations | 22 | ||
| second order nonlinear differential equation problem | Introductory Physics Homework | 17 | ||
| Help in solving a second-order linear differential equation | Differential Equations | 1 | ||
| Solving a Second-Order Differential Equation | Calculus & Beyond Homework | 10 | ||
