What is the Derivative of a Cross Product?
The derivative of a cross product is addressed in the context of the expression \(\frac{d}{d\mathbf{r}}( \frac{m}{2} |\mathbf{\omega}\times\mathbf{r}|^2)\), leading to the result \(\mathbf{r}\omega^2-\mathbf{\omega}(\mathbf{\omega}.\mathbf{r})\). The discussion emphasizes the application of the product rule for both dot and cross products, confirming that the constant \(\frac{m}{2}\) should not be ignored. The final solution was reached after clarifying the necessary components and correcting an oversight regarding the constant factor.
  • Understanding of vector calculus, specifically derivatives of vector functions.
  • Familiarity with cross products and dot products in vector algebra.
  • Knowledge of the product rule for differentiation applied to vectors.
  • Basic concepts of physics related to angular momentum and rotational dynamics.
  • Study the product rule for vector differentiation in detail.
  • Explore the properties and applications of cross products in physics.
  • Learn about angular momentum and its mathematical representation.
  • Investigate advanced topics in vector calculus, such as the Levi-Civita symbol and its applications.
Students studying physics or mathematics, particularly those focusing on mechanics and vector calculus, as well as educators seeking to clarify concepts related to derivatives of vector functions.
plmokn2
[SOLVED] derivative of a cross product
In some lecture notes I'm reading they jump straight from [tex]\frac{d}{d\mathbf{r}}( \frac{m}{2} |\mathbf{\omega}\times\mathbf{r}|^2)[/tex]
to
[tex]\mathbf{r}\omega^2-\mathbf{\omega}(\mathbf{\omega}.\mathbf{r})[/tex]
It's easy to check this by writing out each component but this is messy so there's probably an easier way to do it. Any help appreciated.
Thanks
to
Surely not! There must be an m/2 in there!
Ignoring the constant m/2, [itex]|\omega\times r|^2= (\omega\times r)\cdot(\omega\times\r)[/itex]. Take the derivative of that, apply the product rule- which is true, for vectors, for both dot product and cross product: [itex](\vec{u}\cdot\vec{v})'= \vec{u} '\cdot\vec{v}+ \vec{u}\cdot\vec{v} '[/itex] and [itex](\vec{u}\times\vec{v})'= \vec{u} '\times\vec{v}+ \vec{u}\times\vec{v} '[/itex].
opps I forgot an m in the answer: sorry.
Thanks, I've solved it now.
