MRI Signal Intensity: Optimizing TR & TE
The discussion focuses on optimizing the repetition time (TR) and echo time (TE) in a Spin-Echo MRI experiment to maximize the signal intensity (SI) difference between white matter and gray matter. The signal intensity equations for white matter (SIw) and gray matter (SIg) are defined using proton density and relaxation times (T1 and T2). To differentiate the signals effectively, participants recommend dividing the two equations rather than subtracting them. Additionally, the second derivative test is suggested to confirm whether the critical points found are minima or maxima.
  • Understanding of MRI physics, specifically Spin-Echo sequences
  • Knowledge of relaxation times (T1 and T2) in MRI
  • Familiarity with calculus, particularly partial derivatives and second derivative tests
  • Basic concepts of signal intensity in MRI
  • Study the optimization of TR and TE in MRI sequences
  • Learn about the impact of T1 and T2 on MRI signal intensity
  • Explore advanced calculus techniques for finding extrema in multivariable functions
  • Investigate the differences between various MRI pulse sequences and their applications
Radiologists, MRI technologists, medical physicists, and researchers focused on optimizing MRI imaging techniques and enhancing diagnostic capabilities.
schulzy
We will make a Spin-Echo experiment, and we know [tex]\rho_{w}, T1_{w},T2_{w}, \rho_{g},T1_{g},T2_{g}[/tex], where T1 and T2 are relaxation time,[tex]\rho[/tex] is a proton density, and g mean gray matter, w mean white matter.
We search TR and TE, TR is a repetition time, TE is an echo time. We need this two time define, and be the different of signal intensity biggest. Signal intensity: [tex]SI=\rho\left(1-e^{-\frac{TR-TE}{T1}}\right)e^{-\frac{TE}{T2}}[/tex]
also we have two equation
[tex]SI_{w}=\rho_{w}\left(1-e^{-\frac{TR-TE}{T1_{w}}}\right)e^{-\frac{TE}{T2_{w}}}[/tex] and
[tex]SI_{g}=\rho_{g}\left(1-e^{-\frac{TR-TE}{T1_{g}}}\right)e^{-\frac{TE}{T2_{g}}}[/tex]
and I don't know, what should I do, I divide or subtract the two equation. And after this operation we make a partial derivation:
[tex]\frac{\partial}{\partial TR}f=0[/tex] and [tex]\frac{\partial}{\partial TE}f=0[/tex]
Is this place a minimum or maximum place?
Also my question is, divide I or subtract the two equation?
Since you presumably want to differentiate grey and white matter, you want the biggest ratio of the two signals--so you divide the two equations.
The classic way to tell whether you have found a minimum or maximum is to then evaluate the 2nd derivative at the value of extremum that you found from the 1st. If the 2nd derivative is positive it's a minimum, negative = max, 0 = inflection point. Your text, it probably has additional info on extrema and 2nd derivatives.
  • · Replies 17 ·
  • · Replies 16 ·
  • · Replies 0 ·
